machina |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 ![]() ![]() |
In case anyone else besides paul is interested, here are my older and newer oil lines.
The earlier verion (bottom) was just too small (ID). I didn't want to have that long solid length of connectors like in the top pic hanging off the pump but there was no other way to fit the big hose ends form the -10 lines. Attached thumbnail(s) ![]() |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,307 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
David,
It was as if you're reading my mind (or my PM). I'm going to run longer nipples(!) before I connect my hoses but it's the same set up. Thanks (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) P |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
Much better!!!!
David- Call me tonight..... Paul- Send me the rocker studs off the JYD, and PLEASE mail them to me.... someone forgot to pull them and ship them to me... (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) |
URY914 |
I'll pull them tonight and MAIL them tomorrow. (IMG:http://www.914world.com/bbs2/html/emoticons/flag.gif) |
URY914 |
US fine thread not metric, I see.... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Jake Raby |
Yeah- I had to make them, thats why I need them back..
URY914 |
I got them off just now. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Jake Raby |
Sweet!
Theyare going on the "Super 2 Liter"..... or atleast they are going on it for a portion of the dyno work... |
URY914 |
here is yo' studs... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
URY914 |
I had to take some material off the mounting bracket for the nipple to clear.
Pretty (IMG:http://www.914world.com/bbs2/html/emoticons/wub.gif) Attached thumbnail(s) ![]() |
URY914 |
ssss
URY914 |
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Jake Raby |
Thanks man!!
Now fire that bitch up!!!!! I have the fan that was balanced to the assembly as well, ( I had that baby set up for multiple applications, so if you want to DTM it later I have that pulley as well already balanced) I'll send it to you with the other goodies we talked about... |
URY914 |
Jake,
I need to send you these 2.0 heads too. I'm adding a small tab onto the bracket that will make up for the material I took off of it. I'll post some pics of it tomorrow after I weld it together. It is trick. (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif) I'm also going to get the remote filter mount tomorrow at Fisher's Buggies. I've been working every night on it. (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/sawzall-smiley.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/type.gif) Paul (IMG:http://www.914world.com/bbs2/html/emoticons/givemebeer.gif) |
Brett W |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,856 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None ![]() ![]() |
Paul
You need to brace those fittings. The soft brass will fracture and break off due to the engine vibration. Some sort of bracket that comes from the block to the end of the fittings (where the hoses attach) should work well. Just use a large insulated hose clamp type piece and attach it to your bracket. This would be bolted to your bracket so you can remove the hose. |
maf914 |
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None ![]() ![]() |
Paul, What is the white stuff on the threaded fittings? Liquid teflon thread compound?
machina |
I didn't even like using the 1.5" nipple on the pump side but I had no choice. The return port shouldn't need any extension at all. I had clearance for the -10 line and fitting. Those long solid extensions are leaks waiting to happen. |
URY914 |
Yep. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
URY914 |
I'll take the top nipple off and only use the barbed fitting at the 90 degree fitting. I can take a padded hose clamp attach it to the engine bar. Than use tie wrap to hold it all together. Thanks for the input. (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif) P |
URY914 |
This is what I'm thinking...
I'll weld a small tab on the engine bar to attach the clamp. The oic is too dark to see the black engine bar. Attached thumbnail(s) ![]() |
Lo-Fi Version | Time is now: 27th June 2024 - 03:17 AM |
