> Fuel sender readings ?
jims914
post Oct 29 2024, 05:55 PM
Anyone have any luck with a factory (porsche) dank, URO ?
There is a big difference in price ?
I know they are a simple unit.
Have had a new one and they still do not read very good ?
Replies(1 - 11)
FlacaProductions
post Oct 29 2024, 06:37 PM
I just replaced my OEM one (wasn't going all the way to the top) with one from SMC (aftermarket) and now it jitters.
I did have to tighten up the pins as they were loose compared to the OEM but even with the tight pin/socket connection, it acts like a bad ground...I haven't had time to investigate further. Really annoying to take off the expansion chamber multiple times for something that should be a direct plug and play.
jims914
post Oct 29 2024, 07:56 PM
Mine on a full tank reads half full.
Its too bad there is not a way to correct the float to read correct going up or down ?
Anyone have a fix ?
Chris914n6
post Oct 29 2024, 10:41 PM
Jackstands are my life.
BTDT
Open it up and clean it
930cabman
post Oct 30 2024, 04:55 AM
QUOTE(Chris914n6 @ Oct 29 2024, 10:41 PM) *
BTDT
I have had mixed results with the above. IIRC I had a couple extras laying around and got about 1/2 of them to work decently
FlacaProductions
post Oct 30 2024, 08:50 AM
Yeah - I was going to replace mine and then open up the old one to see what's what - but I dropped it while taking it out - but maybe that's what it needs. I've had them apart on a different 914 years ago with success. They're just delicate inside.
VaccaRabite
post Oct 30 2024, 11:03 AM
En Garde!
Mine reads about 3/4 full on a full tank of gas. I can get it to read 4/4 IF I fill the expansion tank too, which is not a great idea.
3/4 full it is.
But my car will get to 1/4 full and stay there for close to 100 miles before the gauge reads lower. I just fill the tank whenever I go anywhere and treat the gas gauge as an educated guess.
Zach
worn
post Oct 30 2024, 06:00 PM
can't remember
QUOTE(VaccaRabite @ Oct 30 2024, 10:03 AM) *
3/4 full it is.
Zach
When I made my triple gauge, I pulled the needle and put it back wrong. Out of gas when it said a quarter full. Fortunately the light still came on. Tried it again and went a bit too much in the wrong direction. I will get it right sooner or later. I have often wondered about putting a little potentiometer in line with gauges to set the baselines. Never tried it.
fixer34
post Oct 30 2024, 06:50 PM
Use the gauge as an estimate and the warning light as a 'stop at next gas station'.
Spoke
post Oct 30 2024, 07:24 PM
Jerry
I had luck cleaning the OEM sender. Carefully cleaned and 2000 grit sanded the wires and it works well now. I fill up when I get to 1/2 tank on my 914 and my 930.
bkrantz
post Oct 30 2024, 08:03 PM
QUOTE(fixer34 @ Oct 30 2024, 06:50 PM) *
Yup. The sender is just a guesstimate on good days. If it indicates more than 1/2 full you have plenty os gas. Under 1/2 means you could run out soon.
jims914
post Oct 30 2024, 10:49 PM
Thanks guys for all the input will try the 2000 grit sanding to he wire.
Hate to have to order a factory one at $400.00 +
- Lo-Fi Version Time is now: 1st November 2024 - 02:15 AM
