High Idle, what's going on? |
mistro |
Aug 26 2005, 11:44 PM
Member Group: Members Posts: 148 Joined: 12-March 04 From: Highland Park, IL Member No.: 1,786 Region Association: None |
My 73 2.0 with stock fuel injection and 53,000 miles, today was idleing at 2000 rpm consistently. This is at least 1000 to 1200 rpm more than the last time I drove it two weeks ago. Any ideas of what is going on? Never given me a lick of trouble before this. Thanks in advance. Rgds, Michael
redshift |
Aug 27 2005, 12:08 AM
Bless the Hell out of you! Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
'ave you looked at anything? (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif)
Vac leak, could be anything. The AAR may have failed open. You have a hose leak. A hose slipped off of something. Throttle return spring may be worn out, check the spring. Your oil bypass valve may have failed, warning of unstoppable pending engine doom. Your valves will be consumed by fire, and all your bearings melt down, while you sit at idle waiting for a light to change, after a low speed trip through a neighborhood. I was just kidding about the last one. M |
dennisc |
Aug 27 2005, 03:00 AM
Member Group: Members Posts: 90 Joined: 1-September 04 From: Marshall, MO Member No.: 2,671 |
With the car running, try pulling the hose off the aux air regulator and plugging it or covering it with your finger. If the idle drops the aux air regulator may be bad.
Automotive Hindenburg |
Aug 27 2005, 05:46 AM
Newbie Group: Members Posts: 17 Joined: 20-April 05 From: Atlanta, GA Member No.: 3,955 |
Make sure the engine is warmed up before checking the AAR. If the AAR is ok, check the PCV valve and related hoses.
SirAndy |
Aug 30 2005, 03:42 PM
Resident German Group: Admin Posts: 41,957 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
vacuum leak. most likely, one of the vac hoses has come off ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
Bleyseng |
Aug 30 2005, 06:10 PM
Aircooled Baby! Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
vac leak or AAR valve is stuck open.... (IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif)
Deano |
Aug 30 2005, 09:33 PM
Member Group: Members Posts: 83 Joined: 13-October 04 From: Des Moines, Iowa Member No.: 2,942 |
I had the same problem up until yesterday. The vac hose to the advance on the distributer was not as snug as it should have been. Clipped about 1/2 off, put it back on and the idle dropped right down to were it should be.
Let us know what you find. Good Luck |
Lo-Fi Version | Time is now: 4th January 2025 - 11:10 PM |
