> Repairing the main seal leak, Finally got to the first part of it.
mmichalik
post Nov 11 2024, 09:46 AM
MikeM
I was able to get some time this weekend, at the cost of all of the household chores, to pull the motor so I can start repairing the main seal leak.
I was a bit nervous about doing it for the first time but, It was relatively straight forward and much easier then I thought it would be.
Hopefully I can get back to the job this weekend so we can button this thing up and I can start driving it again.
Thanks to @ChrisFoley for the engine lift plate. Thing worked like a charm!
Here are a couple pictures:
Replies(1 - 17)
mmichalik
post Nov 11 2024, 09:50 AM
MikeM
Dropped the engine so I can fix the oil leak
JeffBowlsby
post Nov 11 2024, 10:02 AM
914 Wiring Harnesses
While you are in ther you have to at least get a valve adjustment, and what else can you do that will save you time later?
mmichalik
post Nov 11 2024, 10:21 AM
MikeM
QUOTE(JeffBowlsby @ Nov 11 2024, 08:02 AM) *
(IMG:style_emoticons/default/wink.gif)
Great suggestions. I will do just that.
Thanks @JeffBowlsby
rjames
post Nov 11 2024, 11:23 AM
I'm made of metal
I'd also do the oil cooler seals. Although, based on how clean everything looks, I'm' guessing you don't need them. (IMG:style_emoticons/default/smile.gif)
JeffBowlsby
post Nov 11 2024, 02:07 PM
Unless you know they are recently changed, if it were me I would also replace the front & rear main seals, the front trans shaft seal and inspect the clutch disk and first/reverse gear assembly
mmichalik
post Nov 11 2024, 02:56 PM
MikeM
The entire unit, from front to back, has probably less than 200 miles on it since the rebuild of the engine and transmission. Which I had done by people who definitely know what they are doing and is why it's so clean right now.
Checking the valves, while it's out is a good idea. The other pieces should be brand new.
The rear main seal was not put in with a tool, just by hand and I think that's the culprit. Particularly since the hand that put it in was unskilled (read = Mine) when we put the clutch on and mated the transmission to the engine.
I will eyeball everything that has been mentioned though, just to make sure.
Jack Standz
post Nov 11 2024, 03:25 PM
When you put the new seal in, this tool helps get things lined-up properly:
https://gowesty.com/products/rear-main-flyw...=41426745753765
And, you should check the clutch disk. If it's contaminated with oil, best to replace it now.
mmichalik
post Nov 11 2024, 03:34 PM
MikeM
QUOTE(Jack Standz @ Nov 11 2024, 01:25 PM) *
That's the one I purchased already. Glad to see I grabbed the right thing.
I've ordered a new clutch disk as well. If the amount of oil that spilled out is any indication, it will probably need to be replaced and if not, I'm building a new engine that I can use it on.
930cabman
post Nov 14 2024, 05:58 AM
Might check the trans input shaft also for leakage
Superhawk996
post Nov 14 2024, 08:13 AM
(IMG:style_emoticons/default/smilie_pokal.gif) on knowing how to drop the engine / trans / exhaust / muffler as an assembly. This is the easiest way to do it in my opinion.
mmichalik
post Nov 14 2024, 11:33 AM
MikeM
QUOTE(Superhawk996 @ Nov 14 2024, 06:13 AM) *
Thanks! It just seemed like the most logical way to do it.
Now, I just have to wait for parts to arrive. Hopefully I will be able pull things apart and get ready for the new parts this weekend.
technicalninja
post Nov 14 2024, 12:29 PM
Raby does case mods to help the RMS housing drain. He puts a little V in the parting line at the bottom.
The original set up has a drain as well. It's just higher than it needs to be.
Make SURE the original drain path is OPEN or you will be doing this again!
Best "practice" is a large drain on the bottom and a smaller air vent on the top.
The OEM has only the drain about halfway up the recess.
bkrantz
post Nov 14 2024, 08:15 PM
Welcome to the drop the engine club. If you do it 2 or 3 more times, it will become a normal reflex for just about any reason.
porschetub
post Nov 14 2024, 09:12 PM
QUOTE(mmichalik @ Nov 15 2024, 05:33 AM) *
Never used seal installer but up to you if not confident on a replacement fitting ,IMO its more important what seal you use , I won't touch anything that isn't a known brand such as Kaco ,Elring etc,I avoid Victor Reinz as found a poor fit in my 911 motor case to the point I have no trust now, they do make great gaskets however.
A good lick of motor oil on the crank and seal lip and a small bit on the OD of the seal helps it go in better you will be fine .
mmichalik
post Nov 15 2024, 09:18 AM
MikeM
QUOTE(porschetub @ Nov 14 2024, 07:12 PM) *
I have the Elring seal for this job. The one I had in there was from GoWesty but like I said, I'm sure we damaged it putting it in.
Hopefully, it's "2nd time is a charm" on this (IMG:style_emoticons/default/smile.gif)
Superhawk996
post Nov 15 2024, 11:14 AM
Pay close attention to the flywheel sealing surface. If you have a groove there - it will never seal properly regardless of what seal you use.
930cabman
post Nov 15 2024, 01:40 PM
QUOTE(bkrantz @ Nov 14 2024, 09:15 PM) *
"normal", I joined the club figuring you guys were all nuts and hoped I might fit right in
- Lo-Fi Version Time is now: 28th November 2024 - 02:35 AM
