> Fuel Pressure Regulator
StratPlayer
post Nov 13 2024, 08:20 PM
StratPlayer
Going to slap one of these into my new motor, I saw where PMB was building a new 2258 and had one of these units installed on the motor.
https://thedubshop.com/universal-fuel-press...or-package-914/
Replies(1 - 8)
bkrantz
post Nov 13 2024, 08:29 PM
That's what I have in my system (from the Dub Shop). No complaints, so it must be working. (IMG:style_emoticons/default/biggrin.gif)
Actually, I do know that it reaches and holds required pressure, based on when I had a manual gauge plumbed into the engine fuel line loop.
GregAmy
post Nov 13 2024, 08:31 PM
I use it on my Microsquirt-converted D-Jet. 3-bar solid with my standard D-Jet pump.
Also used it on my Microsquirt-converted Toyota MR2 race car. Solid there, too.
jim_hoyland
post Nov 15 2024, 12:34 PM
Get that VIN ?
QUOTE(StratPlayer @ Nov 13 2024, 06:20 PM) *
How did you mount it ? I’m
StratPlayer
post Nov 15 2024, 04:22 PM
StratPlayer
QUOTE(jim_hoyland @ Nov 15 2024, 11:34 AM) *
It mounts where the old fuel pressure regulator goes install is easy.
jim_hoyland
post Nov 15 2024, 07:21 PM
Get that VIN ?
Can it adjust the fuels pressure ?
bkrantz
post Nov 15 2024, 08:17 PM
Here's how I mounted mine. First the Dub Shop bracket.
bkrantz
post Nov 15 2024, 08:19 PM
And regulator.
GregAmy
post Nov 16 2024, 08:08 AM
QUOTE(StratPlayer @ Nov 15 2024, 05:22 PM) *
Ditto. I just screwed mine into that same flange using its fittings.
QUOTE(jim_hoyland @ Nov 15 2024, 08:21 PM) *
No, it's fixed at 3 bar. If you're tuning most EFIs at our level then that's a good baseline.
Stock D-Jet fuel pressure is 28; 3 bar is 43.5 psi. You could account for that with a tunable MPS from Tangerine: https://tangerineracing.com/shop/ols/produc...t-mps-diaphragm
Mario also offers a 4 bar: https://thedubshop.com/fuel-pressure-regulator-builder/
Being a standard Bosch regulator, you could possibly find alternatives.
- Lo-Fi Version Time is now: 28th November 2024 - 02:44 AM
