> Shift knob won't stay on, What's the fix?
drmitch
post Nov 23 2024, 11:49 AM
Hi all,
The new 914 went into the shop for a couple of things. One thing they did was take out the atrocious short shifter that a PO had installed and replaced it with factory. It's a huge improvement. HOWEVER...while the shift knob on the short shifter seemed to be solidly attached for eternity, the knob on this replacement came off in my hand before I got out of the parking lot.
I circled back and a tech wrapped some black electrical tape around the shaft and tried several times to get the knob to grip. He did so, but told me it probably wouldn't last and what I need is a knob with a set screw.
Since these didn't come with a set screw, and since the previous knob didn't have this problem, and since I just dropped $500 at the shop, I think it's reasonable to expect the new knob to be as good as the old. The new knob came off in my hand twice on the drive home. I've sent an email to the shop owner asking for a solution.
What say you all? Yes, there is a crush sleeve up in the knob. If the solution is to put a new one in there, please tell me how to get this one out. If the solution is epoxy, I'll do it. If the solution is a knob with a set screw, please point me towards a source. I couldn't find one yesterday online.
THANKS!
Replies(1 - 12)
RAX914
post Nov 23 2024, 11:57 AM
Is it a factory shift knob like the picture below? If so it uses a crush sleeve.
You can find it here:
https://sierramadrecollection.com/search?qu...=914-shift-knob
Superhawk996
post Nov 23 2024, 12:06 PM
QUOTE(drmitch @ Nov 23 2024, 01:49 PM) *
Such a shame there are so many shops out there charging good money . . . Yet they have absolutely no idea about what they are doing on 914’s. (IMG:style_emoticons/default/headbang.gif)
technicalninja
post Nov 23 2024, 12:31 PM
QUOTE(Superhawk996 @ Nov 23 2024, 12:06 PM) *
Real technicians are a dying breed!
Anything 20+ years old really needs a "specialist", someone who intentionally chooses that brand or that "style" of car.
Got an early Mustang or Camaro? It's best to go to a "muscle car" restorer.
Same with old Porsches!
The best shops will mirror Mepstein's place or Unobtanium...
Old Porsche shit EVERYWHERE!
It's when you take it to such a place, and they still don't have a clue...
(IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif)
drmitch
post Nov 23 2024, 12:52 PM
Thanks to all who've commented. As I said in the original post, there is a crush sleeve up in the knob. Again, if a new one is the fix, please tell me how do I get the old one out? I would have thought that the shop would have used a new crush sleeve, but maybe not. The shop I went to is a well-known indy Porsche shop in my area. They probably had thirty+ vintage Porsches on the premises, though mine was the only 914. Mostly 911s and 912s, with one authentic 356 in the mix. Aren't these knobs the same as on any 911 with the 901 gearbox? If so, I don't know that the shop would require any specialized knowledge regarding the shift knob. There was an old red leather Momo knob on the shifter that they used, which they removed and replaced with the OE style knob.
RAX914
post Nov 23 2024, 01:00 PM
The crush sleeve should only be held in the knob by friction. Use a pick, long nose pliers or try slamming the knob on a wooden surface to get it out. Be creative!
NARP74
post Nov 23 2024, 01:12 PM
You can also take some measurements for the full engagement depth to make sure it is on all the way.
I carved out a wood block with a countersunk hole in it so I could smack the knob on all the way with a hammer and not damage the knob. Put a cloth on top for full protection.
Sometimes hand pressure is just not enough.
Cairo94507
post Nov 23 2024, 01:46 PM
Michael
New crush sleeve and make sure that the knob gets seated all the way down. I have seen some where in addition to the new crush sleeve they small slip of the old crush sleeve into the knob too. I put a new factory knob on my stock shifter lever with a new crush sleeve and it fits very tight. Good luck.
OH, find another shop. If their solution is electrical tape.... (IMG:style_emoticons/default/chair.gif)
Superhawk996
post Nov 23 2024, 02:01 PM
QUOTE(drmitch @ Nov 23 2024, 02:52 PM) *
Yup same.
All the more appalling that some Goofus was suggesting you need a knob with set screws. (IMG:style_emoticons/default/chair.gif)
fiacra
post Nov 23 2024, 03:37 PM
Person.Woman.Man.Camera.TV
You went to a local well known independent Porsche shop and got out of there with a bill for only around $500? They must have liked you.
Looks like your question has been well answered by others. My loose shift knob was fixed with the judicious application of force to seat it using what the military has termed "an inertially enhanced impact device" (aka a hammer). I used a wood block held on top of the shift knob. I like the advice about drilling out a hole in the wood block that fits on top of the knob. I used a piece of soft wood, but that would also have been helpful in distributing force. I didn't use a new crush washer, and the knob stayed in place for the few years I owned the car. I'd probably start there if you are worried about trying to get the crush washer out. If it doesn't stay on after giving it a few good whacks, then replace the crush washer. I think a trip back to the shop to have them deal with it will just take more time out of your day and probably more money out of your pocket.
Front yard mechanic
post Nov 23 2024, 04:01 PM
I use a booger to hold mine tight
NARP74
post Nov 23 2024, 06:41 PM
A Tanya Harding #20 should do the trick.
bkrantz
post Nov 23 2024, 08:15 PM
If you want DAPO style, use epoxy (and never get that knob off in one piece).
If you want to be correct, get a new crush washer. And if you can't get the old one out of the old knob (and if the old knob is worn), just get another one of those.
2 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
1 Members: Mike Knox
- Lo-Fi Version Time is now: 24th November 2024 - 09:28 AM
