Injectors and Dejection, Bought the Standard Motor Products Version - Does not fit |
ctc911ctc |
Nov 25 2024, 08:54 AM
Senior Member Group: Members Posts: 942 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
'74 2.0 25K miles, all original, all rebuilt
All, I am chasing the final item on this car, occasional firing miss. At idle and at speed the car occasionally misses, does not terribly effect driving but does effect my peace of mind.... I removed, while idling, each of the injector wires (new harness - thank you Bowsley) and the #1 wire had very small effect on operation. Also, the injector looked a bit weepy, gas leaking around the green plastic. While I was rebuilding the car, all of the injectors were sent to a Bosch guy here in Mass, who has the correct testing equipment. I also bought an additional set on EBAY and sent the originals plus the purchased injectors to him, 7 came back within calibration, one was DOA. (IMG:style_emoticons/default/dry.gif) Yesterday the fun began. I replaced the #1 injector with one of the rebuilt ones, it leaked......then I tried another.......it also leaked....... (IMG:style_emoticons/default/blink.gif) THEN, I tried a new injector I purchased from a reseller, it is manufactured by Standard Motor Products and is listed as compatible with the '74 914 2.0. (IMG:style_emoticons/default/drooley.gif) 1. The hose is pressed onto the injector so I had to try and use it instead of my hoses. (IMG:style_emoticons/default/sad.gif) 2. The hose is too short, making the installation difficult (IMG:style_emoticons/default/headbang.gif) 3. The ID of the hose is too small so it was a force fit. (IMG:style_emoticons/default/headbang.gif) 4. the Spray part of the injector is too short and also narrower than the original (IMG:style_emoticons/default/mad.gif) 5. the fit on the manifold tube is not tight, (I had to make a gasket since the ones I had for the other injectors - all new gaskets- were too small (IMG:style_emoticons/default/dead horse.gif) I gave up on the new injector and re-installed the old one...... Here is the question: Has anyone had luck with these injectors, if so, did you cut off the hose? Are you concerned about the loose fit? Last, perhaps there is another manufacturer that I did not find that you can direct me to? Thank you Teeners! |
Craigers17 |
Nov 25 2024, 09:33 AM
Senior Member Group: Members Posts: 807 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
'74 2.0 25K miles, all original, all rebuilt All, I am chasing the final item on this car, occasional firing miss. At idle and at speed the car occasionally misses, does not terribly effect driving but does effect my peace of mind.... I removed, while idling, each of the injector wires (new harness - thank you Bowsley) and the #1 wire had very small effect on operation. Also, the injector looked a bit weepy, gas leaking around the green plastic. While I was rebuilding the car, all of the injectors were sent to a Bosch guy here in Mass, who has the correct testing equipment. I also bought an additional set on EBAY and sent the originals plus the purchased injectors to him, 7 came back within calibration, one was DOA. (IMG:style_emoticons/default/dry.gif) Yesterday the fun began. I replaced the #1 injector with one of the rebuilt ones, it leaked......then I tried another.......it also leaked....... (IMG:style_emoticons/default/blink.gif) THEN, I tried a new injector I purchased from a reseller, it is manufactured by Standard Motor Products and is listed as compatible with the '74 914 2.0. (IMG:style_emoticons/default/drooley.gif) 1. The hose is pressed onto the injector so I had to try and use it instead of my hoses. (IMG:style_emoticons/default/sad.gif) 2. The hose is too short, making the installation difficult (IMG:style_emoticons/default/headbang.gif) 3. The ID of the hose is too small so it was a force fit. (IMG:style_emoticons/default/headbang.gif) 4. the Spray part of the injector is too short and also narrower than the original (IMG:style_emoticons/default/mad.gif) 5. the fit on the manifold tube is not tight, (I had to make a gasket since the ones I had for the other injectors - all new gaskets- were too small (IMG:style_emoticons/default/dead horse.gif) I gave up on the new injector and re-installed the old one...... Here is the question: Has anyone had luck with these injectors, if so, did you cut off the hose? Are you concerned about the loose fit? Last, perhaps there is another manufacturer that I did not find that you can direct me to? Thank you Teeners! If your intakes and fuel rails are stock from a 74, the Standard Motor FJ67 should work with grommets from Standard Motors. I didn’t have to modify anything. The nose on the injector is more snubbed, but shouldn’t cause a fitment issue. |
ctc911ctc |
Nov 25 2024, 09:56 AM
Thank you for the reply,
They did not sent gaskets/grommets, so I had to improvise - did you use the hose that they provided? Can you cut it off? [/quote] If your intakes and fuel rails are stock from a 74, the Standard Motor FJ67 should work with grommets from Standard Motors. I didn’t have to modify anything. The nose on the injector is more snubbed, but shouldn’t cause a fitment issue. [/quote] T |
FlacaProductions |
Nov 25 2024, 10:02 AM
Senior Member Group: Members Posts: 1,821 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
74 2.0 here - used FJ67s without issue.
Used the hose as delivered. Used their grommets/seals - ordered as additional item - all from Rock Auto. Seals: SK15 (x4) https://www.rockauto.com/en/moreinfo.php?pk...RPuyciqhw%3D%3D The SK3 Rail Kit may also be the ticket for all 4 in one package but I did SK15. https://www.rockauto.com/en/moreinfo.php?pk...RPuyciqhw%3D%3D From my research/search, here are your seal options: https://www.rockauto.com/?carcode=1500866&parttype=13679 |
Craigers17 |
Nov 25 2024, 10:28 AM
[quote name='ctc911ctc' date='Nov 25 2024, 10:56 AM' post='3178817']
Thank you for the reply, They did not sent gaskets/grommets, so I had to improvise - did you use the hose that they provided? Can you cut it off? [/quote] If your intakes and fuel rails are stock from a 74, the Standard Motor FJ67 should work with grommets from Standard Motors. I didn’t have to modify anything. The nose on the injector is more snubbed, but shouldn’t cause a fitment issue. [/quote] T [/quote] I used the hose as it was. I didn’t modify anything. |
Craigers17 |
Nov 25 2024, 11:10 AM
Just to make sure we are comparing apples to apples, here are a few pics from several years ago when I did this. The first two are the actual FJ67:
This is the injector installed(kinda hard to see): The last 2 are of what I believe are stock 009's. I am only showing this pic to reference the 2 grommets that go on the injector: Hope this helps.....it's all I got. |
FlacaProductions |
Nov 25 2024, 12:49 PM
87m491 |
Nov 25 2024, 01:08 PM
Member Group: Members Posts: 324 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States |
'74 2.0 25K miles, all original, all rebuilt All, I am chasing the final item on this car, occasional firing miss. At idle and at speed the car occasionally misses, does not terribly effect driving but does effect my peace of mind.... 1. The hose is pressed onto the injector so I had to try and use it instead of my hoses. (IMG:style_emoticons/default/sad.gif) 2. The hose is too short, making the installation difficult (IMG:style_emoticons/default/headbang.gif) 3. The ID of the hose is too small so it was a force fit. (IMG:style_emoticons/default/headbang.gif) 4. the Spray part of the injector is too short and also narrower than the original (IMG:style_emoticons/default/mad.gif) 5. the fit on the manifold tube is not tight, (I had to make a gasket since the ones I had for the other injectors - all new gaskets- were too small What "loose fit" are you referencing? Injector to manifold should be fixed via proper injectors/gaskets. Loose fit on injector hose swap should be fixed by proper FI hose clamps as seen in previous post. I gave up on the new injector and re-installed the old one...... Here is the question: Has anyone had luck with these injectors, if so, did you cut off the hose? Are you concerned about the loose fit? Thank you Teeners! 1 The hose being crimped onto the injector would be a plus in my book but generally the crimp can be carefully dremmeled open and peeled off. 2 The injector hose would only be too short if your fuel rail is being held "too far away" from the injectors via their other flex hose attachment points. Pretty easily addressed. 3 ID to small is better than too big. (you do have the stock fuel rail?) Some heat and lubricant are your friends here. 4 The spray part of the injector's length shouldn't be an issue as other have mentioned. 5 The poor manifold fit should be fixed with the proper gaskets. Are you sure you received the proper Standard Motor injectors despite what was being offered on Ebay? |
87m491 |
Nov 25 2024, 01:11 PM
ctc911ctc |
Nov 27 2024, 09:43 AM
Thank you for your replies - some responses in line below.
1 The hose being crimped onto the injector would be a plus in my book but generally the crimp can be carefully dremmeled open and peeled off. Yep, just checking if there is a shaft underneath that can take a hose and clamp? 2 The injector hose would only be too short if your fuel rail is being held "too far away" from the injectors via their other flex hose attachment points. Pretty easily addressed. I used hoses from 914Rubber, their length and curve, etc. seem perfect, the amount of length of the hose after the bend on the new injector seems very short in comparison. 3 ID to small is better than too big. (you do have the stock fuel rail?) Some heat and lubricant are your friends here. I do not agree, though I understand your point. These high pressure hoses have 3 lamination's. The internal laminate was ripped and pushed down the tube from trying to get it to fit over the larger pipe (which is the stock fuel rail), I would suggest that in this very important area that having everything fit to spec is a noble quest (IMG:style_emoticons/default/wink.gif) 4 The spray part of the injector's length shouldn't be an issue as other have mentioned. OK, thank you, 5 The poor manifold fit should be fixed with the proper gaskets. Are you sure you received the proper Standard Motor injectors despite what was being offered on Ebay? I did not receive any of the round gaskets, though I have spares (new) from the older injectors when I had them rebuilt. The shaft size at the manifold interface of the new injector is too small, needed to build one. I purchased the injector from a 914 parts company which listed it as compatible for the 2.0L engine and year. Thank you again for this information! [/quote] |
emerygt350 |
Nov 27 2024, 01:51 PM
Advanced Member Group: Members Posts: 2,496 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Are you sure you have fj67s? For me it was complete plug and play when I installed them.
ctc911ctc |
Dec 1 2024, 08:34 PM
I was able to return to this project today, I tried my last 'spare' original though rebuilt-to-spec injector and it operated correctly,
While I was working on this injector problem, I installed a professionally rebuilt distributor and set the dwell angle right on the numbers: 48 degrees. After correcting the injector trouble I moved on to setting the timing. With the 27Deg RED mark only on the rear side of the flywheel I had to draw a mark on the _other_ side so I could get this done with the timing light, etc. Why do they think of a million other things and not think about marking the fly wheel on both sides? I believe that I was about 20+ degrees off, after getting it correct, all of the engine missing just went away. I may be at the end of this journey with this car, drove all day, not a flinch, just worked properly. Like my 2 year old 1.7 in 1973.......ahhhh.... (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/cool.gif) HOWEVER I then noticed that the idle was too high, around 1800. I set the idle screw and it is in all of the way - still around 1800. VACUUM LEAK!?! (IMG:style_emoticons/default/mad.gif) On this car I have had perhaps a dozen different vacuum leaks, manifold gasket (did not seat right), Plenum (needed a complete re-weld), Manifold tube cloth connectors to the plenum (too lose, needed to be snugged a bit closer to the plenum). So, where is this leak? I recently purchased a smoke machine and was using it incorrectly - I thought that I would see the smoke being SUCKED into the vacuum leak.......well, that did not work, then I wanted a few videos and put the smoke in the throttle body and This is what happened: https://youtube.com/shorts/rAf5c66Zow4?si=y3TRgC0EJgBFMfmX Apologies for the bad video, but it seems that the throttle plate shaft in the throttle body is very leaky, any ideas if this is something that could keep the idle high? Also, note that in the video you can see that I plugged (blue plug) the vacuum valve with the heater in it. does not change the idle very much when plugged - perhaps 200 rpm reduction. Any ideas as to the shaft leaks and how tight that part of the vacuum circuit it should be? thank you teeners |
emerygt350 |
Dec 3 2024, 12:51 PM
Considering you have been playing with the injectors, I wonder if the seals around them may not be perfect. I would grab some carb cleaner and give some little squirts around the injectors and see what happens. I never liked the way they were mounted by the factory.
Lo-Fi Version | Time is now: 4th December 2024 - 12:48 PM |
