Does anyone know the floor pan and frunk floor thickness? |
914xr75 |
Nov 26 2024, 09:45 PM
Member Group: Members Posts: 184 Joined: 24-March 18 From: Whittier, CA Member No.: 21,996 Region Association: Southern California |
When I look at any of the replacement pieces, they don’t list a thickness. Does anyone know the thickness of the original metal or patch panels?
Ishley |
Nov 26 2024, 10:07 PM
Member Group: Members Posts: 167 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest |
Most the metal I used for patches etc was 18 gauge. The 20 gauge I had in the shop was just too thin. 18 was a little thicker for most patches (then the original metal) which gave me room to grind a little cleaning up welds etc.
For some reinforcements I used 16.. but it hard to use for anything but simple bends or backing plates where you feel you need it. It’s also heavier. One tip for you going forward is to use Google to search the forum. You’ll find other posts that talk to this subject. In the Google search box type “914 world metal gauge”… or whatever topic you need help with and you’ll find what you need. Good luck! |
mb911 |
Nov 27 2024, 05:03 AM
914 Guru Group: Members Posts: 7,302 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
18 Gauge is pretty typical
Flyinlow |
Nov 27 2024, 08:53 AM
Flyinlow Group: Members Posts: 57 Joined: 17-October 20 From: British Columbia, Canada Member No.: 24,774 Region Association: Canada |
18 ga satin coat for sure
Lo-Fi Version | Time is now: 30th November 2024 - 10:02 PM |
