ECU confusion ?, have one I will sell as not needed |
porschetub |
Nov 28 2024, 05:15 PM
Advanced Member Group: Members Posts: 4,739 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Been on the Anders site and found it is from a 74 2.0 ,lots of confusion from other sources like 73 and 74 including mention it will work with a 1.7 !!!! .
Numbers are ; Bosch 0 280 000 044 , VW 039 906 021 . Pretty sure I have a loom for it in my lockup also which I will test for broken loom wires and repair if required but seem to remember it was in real clean and not crusty and stiff . Bought this way back from a reputable seller but TBO it was purchased a long time ago , Answers appreciated TIA . |
JeffBowlsby |
Nov 28 2024, 06:51 PM
914 Wiring Harnesses Group: Members Posts: 8,760 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Been on the Anders site and found it is from a 74 2.0 ,lots of confusion from other sources like 73 and 74 including mention it will work with a 1.7 !!!! . Numbers are ; Bosch 0 280 000 044 , VW 039 906 021 . Pretty sure I have a loom for it in my lockup also which I will test for broken loom wires and repair if required but seem to remember it was in real clean and not crusty and stiff . Bought this way back from a reputable seller but TBO it was purchased a long time ago , Answers appreciated TIA . I may be interested, depending on cost and condition. Photos? Can you confirm that it is 100% functional? Many of these old ECUs seem to work ok, but when tested have some functional issue. Cost to ship to me in CA 94583? @porschetub |
porschetub |
Dec 2 2024, 03:53 PM
Been on the Anders site and found it is from a 74 2.0 ,lots of confusion from other sources like 73 and 74 including mention it will work with a 1.7 !!!! . Numbers are ; Bosch 0 280 000 044 , VW 039 906 021 . Pretty sure I have a loom for it in my lockup also which I will test for broken loom wires and repair if required but seem to remember it was in real clean and not crusty and stiff . Bought this way back from a reputable seller but TBO it was purchased a long time ago , Answers appreciated TIA . I may be interested, depending on cost and condition. Photos? Can you confirm that it is 100% functional? Many of these old ECUs seem to work ok, but when tested have some functional issue. Cost to ship to me in CA 94583? @porschetub Thanks for the offer but haven't found the loom yet but know I have it ,as mentioned ECU is untested ,would prefer to sell a bit more local as I'am in New Zealand so most like sell to someone in my country or Australia ,cheers. |
JamesM |
Dec 3 2024, 08:32 PM
Advanced Member Group: Members Posts: 2,000 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Been on the Anders site and found it is from a 74 2.0 ,lots of confusion from other sources like 73 and 74 including mention it will work with a 1.7 !!!! . Numbers are ; Bosch 0 280 000 044 , VW 039 906 021 . I think a lot of the confusion on the 2.0 d-jet parts happen because the change over from the early 2.0s that uses the funky one year only CHT and the later 2.0 ECUs that use the more common CHT happened in 73 not 74. The early 2.0s used the 1.7 ECU however that stopped sometime in 73 and the remaining 73s got the same part as the 74 cars. So Anders site isn't technically 100% correct calling them 74 ECUs. |
Lo-Fi Version | Time is now: 4th December 2024 - 01:10 PM |
