> 914World Classifieds Rules
> Valve adjusting screws from 1973 2.0, 8mm large contact area SOLD
914ltd
post Dec 1 2024, 06:58 PM
The 1973 2.0 used an 8mm adjusting screw that almost never wore PN 039.109.451.
No longer available. The contact area to the valve was much larger than the other 8mm screws. I don't ever remember replacing these screws due to pitting and worn areas that the small contact 8mm screws and especially the 10mm adjusting screws failed with. These adjusting screws will also help prevent pitting and damage to the valve stems. Changing to the "wobble foot" 911 8mm valve screw requires grinding the rocker arm, respacing the rocker assembly and resetting the geometry to correctly install.
These used adjusting screws will require 8mm rocker arms but will require only regular valve adjustments. Lock nuts are included, $100. Shipped
SOLD, Thanks!
Replies(1 - 4)
jim_hoyland
post Dec 1 2024, 08:07 PM
Get that VIN ?
What size do the later ‘75 L-Jet motors use ?
914ltd
post Dec 2 2024, 07:19 AM
QUOTE(jim_hoyland @ Dec 1 2024, 06:07 PM) *
The 1974 1.8 and all 1975 and later engines (including 1.8) used 10X1 adjusting screws. Brad
anderssj
post Dec 3 2024, 10:30 AM
Dog is my copilot...
Brad,
Thanks for posting this. Would engine GA005694 use these adjusting screws? If it doesn’t already have them, then I’m interested.
Thanks!
Steve A-
anderssj
post Dec 3 2024, 10:46 AM
Brad, I’ll take them. PM sent.
Steve A-
- Lo-Fi Version Time is now: 5th February 2025 - 02:54 AM
