914-6 3.6 wevo, Problem with the gears |
Fred914-993 |
Dec 10 2024, 09:44 AM
Newbie Group: Members Posts: 5 Joined: 10-December 24 From: Royan Member No.: 28,508 Region Association: France |
Hello everyone,
(IMG:style_emoticons/default/driving.gif) Fred from France, I bought a Porsche 914-6 converted with a 3.6 from 993 c2, the engine starts well, but the previous mechanic fitted a Wevo side shift kit, The mechanic where the car is tells me that there is a problem with the location of the gears on the gearshift grid. Reverse gear is in place of first gear, do you have a spare part or a solution to sell me to stop the problem? or is it a mistake in the assembly of the wevo kit? Has anyone seen this problem? Thank you |
Steve |
Dec 10 2024, 10:26 AM
914 Guru Group: Members Posts: 5,764 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Hello everyone, (IMG:style_emoticons/default/driving.gif) Fred from France, I bought a Porsche 914-6 converted with a 3.6 from 993 c2, the engine starts well, but the previous mechanic fitted a Wevo side shift kit, The mechanic where the car is tells me that there is a problem with the location of the gears on the gearshift grid. Reverse gear is in place of first gear, do you have a spare part or a solution to sell me to stop the problem? or is it a mistake in the assembly of the wevo kit? Has anyone seen this problem? Thank you (IMG:style_emoticons/default/welcome.png) Have you tried calling WEVO? https://www.wevo.com/Products/TransmissionP...ionProducts.htm Otherwise I would try to find a shop over there that has experience with this kit. I went with Martin Bott's 916 kit out of Germany. The WEVO kit is no longer available https://www.bugat5speed.de/en/porsche-cars/...for-porsche-914 http://www.914world.com/bbs2/index.php?showtopic=102988 |
mepstein |
Dec 10 2024, 10:40 AM
914-6 GT in waiting Group: Members Posts: 19,641 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I have a Wevo kitted trans out of a 914-6 3.6 race car. There’s nothing wrong with the Wevo kit, it just has to be installed correctly. If your current mechanic can diagnose the issue, he should be able to fix it, though I’m a bit cautious to think his diagnosis is correct. Did the car ever drive correctly or is the past history completely unknown.
I would want to have it in front of a tech who understands the kit or at least someone who is good at figuring things out. |
Steve |
Dec 10 2024, 10:56 AM
Funny, but it sounds like the mechanic is confusing the 915 with a 914 trans. The 915 has 5th and reverse in the cover, versus the 914 trans has 1st and reverse in the cover. Or maybe I am misreading the post.
mepstein |
Dec 10 2024, 11:15 AM
Funny, but it sounds like the mechanic is confusing the 915 with a 914 trans. The 915 has 5th and reverse in the cover, versus the 914 trans has 1st and reverse in the cover. Or maybe I am misreading the post. (IMG:style_emoticons/default/agree.gif) |
burton73 |
Dec 10 2024, 05:35 PM
burton73 Group: Members Posts: 3,691 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Fred914-993 Welcome to 914World.
You are at the right place to get a WORLD of info. Best Bob B (IMG:style_emoticons/default/welcome.png) |
Fred914-993 |
Dec 11 2024, 05:01 AM
Hello everybody, thanks for your reply.
Yes I sent an email to wevo, but no solution. I don't know what they did with this car, the gearbox has already been disassembled several times. Two mechanics looked but they found nothing. I'm slowly losing hope... When I received the car, the previous mechanic told me that he had only fitted the wevo sidekit. Do you need another part to put the gear lever gate in the right direction? Like the shifter, the psj or the internal gate shift? Or is the sidekit enough on its own? For the assembly of the whole thing, the car has never been driven. It was a car that had been finished building for 15 years... |
Fred914-993 |
Dec 11 2024, 05:03 AM
I have a Wevo kitted trans out of a 914-6 3.6 race car. There’s nothing wrong with the Wevo kit, it just has to be installed correctly. If your current mechanic can diagnose the issue, he should be able to fix it, though I’m a bit cautious to think his diagnosis is correct. Did the car ever drive correctly or is the past history completely unknown. I would want to have it in front of a tech who understands the kit or at least someone who is good at figuring things out. Hello, is your car only equipped with the wevo sidekit? like me, or do you have other elements, like the knob or others? |
rgalla9146 |
Dec 11 2024, 06:25 AM
Advanced Member Group: Members Posts: 4,671 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
If the previous owner says the the Wevo kit was simply installed is it possible the
differential was not flipped ? Maybe the mechanics in France don't know that a 915 is not standard in a 914 ? As Mark asks, is there confirmation the car ever drove (through all gears ?) with the 915 trans ? |
Cairo94507 |
Dec 11 2024, 09:10 AM
Michael Group: Members Posts: 10,123 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
(IMG:style_emoticons/default/welcome.png) You have come to right spot to help you figure this out. If you can post pictures of what you have that may help members help you. (IMG:style_emoticons/default/beerchug.gif)
Steve |
Dec 11 2024, 09:31 AM
I have a Wevo kitted trans out of a 914-6 3.6 race car. There’s nothing wrong with the Wevo kit, it just has to be installed correctly. If your current mechanic can diagnose the issue, he should be able to fix it, though I’m a bit cautious to think his diagnosis is correct. Did the car ever drive correctly or is the past history completely unknown. I would want to have it in front of a tech who understands the kit or at least someone who is good at figuring things out. Hello, is your car only equipped with the wevo sidekit? like me, or do you have other elements, like the knob or others? The shifter has to be a 911/915 shifter. The 914 shifter will not work. Did they replace it? |
rgalla9146 |
Dec 11 2024, 10:29 AM
I have a Wevo kitted trans out of a 914-6 3.6 race car. There’s nothing wrong with the Wevo kit, it just has to be installed correctly. If your current mechanic can diagnose the issue, he should be able to fix it, though I’m a bit cautious to think his diagnosis is correct. Did the car ever drive correctly or is the past history completely unknown. I would want to have it in front of a tech who understands the kit or at least someone who is good at figuring things out. Hello, is your car only equipped with the wevo sidekit? like me, or do you have other elements, like the knob or others? The shifter has to be a 911/915 shifter. The 914 shifter will not work. Did they replace it? Specifically, a 1972 911 shifter which looks just like a 914 one from the top but is different below to suit the non-dogleg pattern... or a '73 on which has the round aluminum housing. |
Steve |
Dec 11 2024, 10:54 AM
I have a Wevo kitted trans out of a 914-6 3.6 race car. There’s nothing wrong with the Wevo kit, it just has to be installed correctly. If your current mechanic can diagnose the issue, he should be able to fix it, though I’m a bit cautious to think his diagnosis is correct. Did the car ever drive correctly or is the past history completely unknown. I would want to have it in front of a tech who understands the kit or at least someone who is good at figuring things out. Hello, is your car only equipped with the wevo sidekit? like me, or do you have other elements, like the knob or others? The shifter has to be a 911/915 shifter. The 914 shifter will not work. Did they replace it? Specifically a 1972 911 shifter which looks just like a 914 one(from the top) or a '73 on which has the round aluminum housing. I tried them all including the one year 1972 915 shifter. I am currently using the JWest Rennshift 915 shifter. The Wevo and Rennshift are springed to the center 3rd and 4th gate and have a shorter throw. The Rennshift is the best because it also has a slightly shorter throw left and right. The 72 915 shifter is the politically correct shifter because it was the only thing available when the 916 came out in 72. |
Fred914-993 |
Dec 20 2024, 09:10 AM
I have a Wevo kitted trans out of a 914-6 3.6 race car. There’s nothing wrong with the Wevo kit, it just has to be installed correctly. If your current mechanic can diagnose the issue, he should be able to fix it, though I’m a bit cautious to think his diagnosis is correct. Did the car ever drive correctly or is the past history completely unknown. I would want to have it in front of a tech who understands the kit or at least someone who is good at figuring things out. Hello, is your car only equipped with the wevo sidekit? like me, or do you have other elements, like the knob or others? Only the side kit |
Fred914-993 |
Dec 20 2024, 09:11 AM
If the previous owner says the the Wevo kit was simply installed is it possible the differential was not flipped ? Maybe the mechanics in France don't know that a 915 is not standard in a 914 ? As Mark asks, is there confirmation the car ever drove (through all gears ?) with the 915 trans ? Le voiture n'a jamais fait un tour de roue dehors!!! |
Steve |
Dec 20 2024, 09:50 AM
If the previous owner says the the Wevo kit was simply installed is it possible the differential was not flipped ? Maybe the mechanics in France don't know that a 915 is not standard in a 914 ? As Mark asks, is there confirmation the car ever drove (through all gears ?) with the 915 trans ? Le voiture n'a jamais fait un tour de roue dehors!!! I would make some phone calls and find a shop that is familiar with Wevo. (IMG:style_emoticons/default/beerchug.gif) |
Jetsetsurfshop |
Dec 20 2024, 03:50 PM
Senior Member Group: Members Posts: 815 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
I installed a 915 with a Vellios side shift kit in my car.
If I remember correctly while using the stock shifter the gears were backwards and upside down. I did put a 915 rennshift in it and it works great. I do miss the dogleg first gear though. (IMG:style_emoticons/default/sad.gif) It's now a 911 5 speed shift pattern. Hope this helps. (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 21st December 2024 - 08:19 AM |
