bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,848 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Warning : Adding shims reduces the number of engaged threads of the 10mm attaching bolts. The stock length of the 10mm bolts is 55mm. If you have a shim pack more than 5mm use new longer 10.9 grade 10 mm bolts. I recently shimmed a 914 to correct the excessive rear camber. One side had about 10mm in shims before adding 3mm more in shims. We had four threads of engagement of the trailing bolts after adding more shim pack. We changed to 70 mm bolts. The other side had a shorter shim pack and the 70mm bolts bottomed out on the non threaded portion of the bolt. 65mm bolts worked.
I had a new batch of stainless steel rear alignment shims in 1, 2, and 3mm thicknesses. Standard shims are 2, 3, an 4mm thick. This assortments easily allows for 1mm increments of adjustment. Any three shims for $35 or 6 for $60 shipped-. each group will include 6 new Schnoor washers as they need to be replaced if the bolts are loosened. \ @technicalninja @FlacaProductions @racer914 Attached thumbnail(s) ![]() ![]() |
technicalninja |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,477 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
I'll take a set of 6.
PM sent. |
FlacaProductions |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,893 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California ![]() ![]() |
I'll take a set of 6. Sending PM, Bruce.
racer914 |
Member ![]() ![]() Group: Members Posts: 89 Joined: 1-October 19 From: Keystone Heights, FL Member No.: 23,513 Region Association: South East States ![]() ![]() |
I'll take 6, let me know how to pay.
sixaddict |
Senior Member ![]() ![]() ![]() Group: Members Posts: 909 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States ![]() ![]() |
Bruce or anyone…..that uses Bird board…
I am getting the following message….i get nervous about changing things with all the #cammers. Anyone else seeing this. See below |
sixaddict |
Sorry deleted repeat
Attached thumbnail(s) ![]() |
bdstone914 |
bdstone914 |
FlacaProductions |
Warning : Adding shims reduces the number of engaged threads of the 10mm attaching bolts. The stock length of the 10mm bolts is 55mm. If you have a shim pack more than 5mm use new longer 10.9 grade 10 mm bolts. each group will include 6 new Schnoor washers as they need to be replaced if the bolts are loosened. Good point -thanks for the reminder! |
bdstone914 |
bump
Lo-Fi Version | Time is now: 3rd April 2025 - 11:30 AM |
