Rear suspension - Keep or change the springs |
PaIsa |
Dec 18 2024, 06:13 AM
Member Group: Members Posts: 63 Joined: 13-June 24 From: Quebec, Canada Member No.: 28,180 Region Association: Canada |
Yesterday I was able to take out the rear shocks & spring as well as one of the rear control arms but breaking 2 bolts in the process! Will find solution for this in the coming days
When I disassemble the shock & spring I found out that I have Weltmeister 180 spring with KYB shock. I plan on replacing the KYB but don't know what to think about the spring. I thought that 100lbs spring was the stock on these cars. The ride was not unpleasant with the current set up so I would consider keeping them. Any advice anyone? The car is a 1972 with a 1.7L engine. Thanks |
Front yard mechanic |
Dec 18 2024, 06:41 AM
Senior Member Group: Members Posts: 1,243 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
180s are great if your girlfriend is 400 lbs
mlindner |
Dec 18 2024, 06:50 AM
Senior Member Group: Members Posts: 1,592 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
180 is typical for a six and the start point for a track car. I would go softer .
mepstein |
Dec 18 2024, 07:15 AM
914-6 GT in waiting Group: Members Posts: 19,656 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Springs wear out. I would go new at 100lbs. Stock was 60-70 but that's too low if you want a performance ride.
Shivers |
Dec 18 2024, 07:21 AM
Senior Member Group: Members Posts: 2,831 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Yesterday I was able to take out the rear shocks & spring as well as one of the rear control arms but breaking 2 bolts in the process! Will find solution for this in the coming days When I disassemble the shock & spring I found out that I have Weltmeister 180 spring with KYB shock. I plan on replacing the KYB but don't know what to think about the spring. I thought that 100lbs spring was the stock on these cars. The ride was not unpleasant with the current set up so I would consider keeping them. Any advice anyone? The car is a 1972 with a 1.7L engine. Thanks I have 140's same company and it is stiff. But it is good for play, and with the wife in it we did some long rides without complaint. I do not know your master plan, but I'd bet the 180's would be good trading stock for something less stiff. |
Superhawk996 |
Dec 18 2024, 07:42 AM
914 Guru Group: Members Posts: 6,607 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
There is no one size fits all answer.
It depends on what you want. Do you want a plush, soft ride or do you want crisp, responsive handling? Street use, auto cross, or track use? Do you have anti-roll bars and what size? Front bar only, rear bar only, or both front and rear anti roll bars? What front torsion bars do you have? Front bar only or both front and rear anti roll bars? What tires are on the car? Do you prefer a vehicle that oversteers (like an early 911) or do you prefer the safety of understeer (typical modern vehicle). This book is a must read if you really want to set up a vehicle to your specific liking. Fred Puhn author |
Superhawk996 |
Dec 18 2024, 07:43 AM
campbellcj |
Dec 18 2024, 08:30 AM
I can't Re Member Group: Members Posts: 4,595 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
Long long ago I ran 140s for a street+autocross capable setup, worked well
PaIsa |
Dec 18 2024, 08:42 AM
There is no one size fits all answer. It depends on what you want. Do you want a plush, soft ride or do you want crisp, responsive handling? Street use, auto cross, or track use? Do you have anti-roll bars and what size? Front bar only, rear bar only, or both front and rear anti roll bars? What front torsion bars do you have? Front bar only or both front and rear anti roll bars? What tires are on the car? Do you prefer a vehicle that oversteers (like an early 911) or do you prefer the safety of understeer (typical modern vehicle). This book is a must read if you really want to set up a vehicle to your specific liking. Fred Puhn author I would be looking for a confortable ride for street use. We will not track or race this. This car is used for short rides during the few months of adequate weather here in Canada! There are no anti-roll bars on the car (front or rear). Tires are wider then stock but I don't have the information currently. I am not looking to set up the vehicle to my specific liking but rather want to make it fun and confortable to ride. I think I would be leaning towards going to a softer spring, but will see. I will likely place the order before the end of the year. |
Geezer914 |
Dec 18 2024, 08:45 AM
Geezer914 Group: Members Posts: 1,799 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
I have 140's in the rear for spirated driving along with 19mm torsion bars up front.
Shivers |
Dec 18 2024, 08:59 AM
I have 140's in the rear for spirated driving along with 19mm torsion bars up front. And it handles like a mad man I'll bet, just like mine (IMG:style_emoticons/default/smile.gif) |
zoomCat |
Dec 18 2024, 10:57 AM
Member Group: Members Posts: 184 Joined: 13-August 04 From: Cincinnati, OH Member No.: 2,526 Region Association: None |
The factory used much softer springs than the later aftermarket stuff, even for the competition cars.
NARP74 |
Dec 18 2024, 12:06 PM
Senior Member Group: Members Posts: 1,301 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Saving those 2 posts for future reference. Thanks.
mb911 |
Dec 18 2024, 12:40 PM
914 Guru Group: Members Posts: 7,373 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I went stock -6 from auto Atlanta and they were perfect for how I use the car which is cruising
brant |
Dec 18 2024, 01:23 PM
914 Wizard Group: Members Posts: 11,825 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Ben driving the street car on 140’s rear with 19mm front torsions and both sway bars for about 30 years
I’m finally ne with this set up Handling is sharp And not too rough |
bkrantz |
Dec 18 2024, 08:31 PM
914 Guru Group: Members Posts: 8,180 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Back in the day, the rule of thumb for "level 1" track/race cars was 140 lb with a rear sway bar and 180 without.
Dec 18 2024, 09:07 PM
sixnotfour |
Dec 18 2024, 09:20 PM
914 Wizard Group: Members Posts: 10,684 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
the old 180 progressive where actually pretty nice..But I dont have a -4..
Mikey914 |
Dec 19 2024, 12:10 AM
The rubber man Group: Members Posts: 12,741 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We've sold quite a few of the 100's, I'm sure there's some one here with a set that can give some feedback. But they are ideal for most street / lite track options.
930cabman |
Dec 19 2024, 05:55 AM
Advanced Member Group: Members Posts: 3,790 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Springs wear out. I would go new at 100lbs. Stock was 60-70 but that's too low if you want a performance ride. (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 30th December 2024 - 10:39 AM |
