Water cooled Porsche 6-cylinder dimensions |
technicalninja |
Dec 22 2024, 01:27 AM
Advanced Member Group: Members Posts: 2,099 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
I have a complete running 99 Boxster 5spd with a quarter million miles on it.
It's roachy enough to turn into an "Organ Donor". I'm a sucker for 4 valve, modern digital FI, COP, and modern accessories. I look at the Boxster and think "Wonder if I can fit that in the 914?". I think it might be possible. After conversion I would most likely replace it with a Boxster S or maybe even a 911 engine. The drive package I'd rather use is a Boxster/Cayman S with the six speed but I own the 2.5L 5 speed now. There is a good chance I can part the 986 out and make money as it came with a factory hardtop. I want to "vulture" the calipers anyway. Are the water-cooled sixes dimensionally identical externally? Have others tried before? I did find this. At least one has been done! https://forums.pelicanparts.com/porsche-914...conversion.html |
mb911 |
Dec 22 2024, 05:22 AM
914 Guru Group: Members Posts: 7,366 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Interesting thread you linked. If you have both patients why not? The donor engine and a willing recipient.
Shivers |
Dec 22 2024, 07:03 AM
Senior Member Group: Members Posts: 2,822 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
At the end he talks about having swapped it out for a 3.2 S engine. Not much room but it is do-able. (IMG:style_emoticons/default/idea.gif) Nice design on the rear trans mount.
ClayPerrine |
Dec 22 2024, 07:32 AM
Life's been good to me so far..... Group: Admin Posts: 15,950 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
IIRC..... it won't fit. The engine is too wide to fit between the trailing arm mounts.
Now if you want to put the whole rear suspension under the 914, then it would fit. Clay |
BillC |
Dec 22 2024, 08:35 AM
Senior Member Group: Members Posts: 575 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
I have a complete running 99 Boxster 5spd with a quarter million miles on it. It's roachy enough to turn into an "Organ Donor". I'm a sucker for 4 valve, modern digital FI, COP, and modern accessories. I look at the Boxster and think "Wonder if I can fit that in the 914?". I think it might be possible. After conversion I would most likely replace it with a Boxster S or maybe even a 911 engine. The drive package I'd rather use is a Boxster/Cayman S with the six speed but I own the 2.5L 5 speed now. There is a good chance I can part the 986 out and make money as it came with a factory hardtop. I want to "vulture" the calipers anyway. Are the water-cooled sixes dimensionally identical externally? Have others tried before? I did find this. At least one has been done! https://forums.pelicanparts.com/porsche-914...conversion.html Keep in mind that '97-'99 Boxsters are the donor cars for the Spec Boxster (SPB) racing class. Those early boxsters are actually going up a little in value, as more people look to get into the class or look for more spare parts (engine & trans). So, you may want to consider selling your car as a race donor, and get a newer (and potentially cheaper) boxster to use as an engine donor. |
technicalninja |
Dec 22 2024, 11:26 AM
I have a complete running 99 Boxster 5spd with a quarter million miles on it. It's roachy enough to turn into an "Organ Donor". I'm a sucker for 4 valve, modern digital FI, COP, and modern accessories. I look at the Boxster and think "Wonder if I can fit that in the 914?". I think it might be possible. After conversion I would most likely replace it with a Boxster S or maybe even a 911 engine. The drive package I'd rather use is a Boxster/Cayman S with the six speed but I own the 2.5L 5 speed now. There is a good chance I can part the 986 out and make money as it came with a factory hardtop. I want to "vulture" the calipers anyway. Are the water-cooled sixes dimensionally identical externally? Have others tried before? I did find this. At least one has been done! https://forums.pelicanparts.com/porsche-914...conversion.html Keep in mind that '97-'99 Boxsters are the donor cars for the Spec Boxster (SPB) racing class. Those early boxsters are actually going up a little in value, as more people look to get into the class or look for more spare parts (engine & trans). So, you may want to consider selling your car as a race donor, and get a newer (and potentially cheaper) boxster to use as an engine donor. OUTSTANDING! You just "Bitch-Slapped" the Ninja! This is the type of info I needed. Dad bought this POS from the original owner. He lives here in Granbury, and he drove it to Dallas every day. It's COMPLETELY stock. All of the work was done by Autobahn (the local P dealer). Paints GONE, both bumper covers show evidence of minor collisions but... It's straight as an arrow, no rust at all. The underside of the car looks better than the top. It's NEVER been in a serious accident. The interior is trashed... It's never been high centered! It doesn't even have "jack" marks on the bottom. This thing is EITHER an organ donor OR it would make a killer chassis to build a track car off of! I'd RATHER start with an S, and I don't need a straight one... Wadded up would work fine! I didn't even think "Don't be stupid, someone might want the pup as a track car". Thank you for the head up @BillC Oh, Dad paid $850 for it as a "not run in 5 years car". I resurrected it and it's all there. I've personally driven it in all 5 gears. I'd guess the hard top is worth $850! |
mepstein |
Dec 22 2024, 12:31 PM
914-6 GT in waiting Group: Members Posts: 19,643 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I have a complete running 99 Boxster 5spd with a quarter million miles on it. It's roachy enough to turn into an "Organ Donor". I'm a sucker for 4 valve, modern digital FI, COP, and modern accessories. I look at the Boxster and think "Wonder if I can fit that in the 914?". I think it might be possible. After conversion I would most likely replace it with a Boxster S or maybe even a 911 engine. The drive package I'd rather use is a Boxster/Cayman S with the six speed but I own the 2.5L 5 speed now. There is a good chance I can part the 986 out and make money as it came with a factory hardtop. I want to "vulture" the calipers anyway. Are the water-cooled sixes dimensionally identical externally? Have others tried before? I did find this. At least one has been done! https://forums.pelicanparts.com/porsche-914...conversion.html Keep in mind that '97-'99 Boxsters are the donor cars for the Spec Boxster (SPB) racing class. Those early boxsters are actually going up a little in value, as more people look to get into the class or look for more spare parts (engine & trans). So, you may want to consider selling your car as a race donor, and get a newer (and potentially cheaper) boxster to use as an engine donor. OUTSTANDING! You just "Bitch-Slapped" the Ninja! This is the type of info I needed. Dad bought this POS from the original owner. He lives here in Granbury, and he drove it to Dallas every day. It's COMPLETELY stock. All of the work was done by Autobahn (the local P dealer). Paints GONE, both bumper covers show evidence of minor collisions but... It's straight as an arrow, no rust at all. The underside of the car looks better than the top. It's NEVER been in a serious accident. The interior is trashed... It's never been high centered! It doesn't even have "jack" marks on the bottom. This thing is EITHER an organ donor OR it would make a killer chassis to build a track car off of! I'd RATHER start with an S, and I don't need a straight one... Wadded up would work fine! I didn't even think "Don't be stupid, someone might want the pup as a track car". Thank you for the head up @BillC Oh, Dad paid $850 for it as a "not run in 5 years car". I resurrected it and it's all there. I've personally driven it in all 5 gears. I'd guess the hard top is worth $850! (IMG:style_emoticons/default/agree.gif) The Boxster spec guys pull the interior top etc. Easy money for you. |
technicalninja |
Dec 22 2024, 01:08 PM
One of the problems with the car was the shifter was baulky and the emergency brake handle didn't work. This blows "inspection" down here.
My son Bryan was tasked to check out what's going on. When he pulled the center console the MONEY poured out... Like an old fashion Vegas slot machine! $47+ in CHANGE! Fixed all of the problems and paid for lunch! (IMG:style_emoticons/default/ninja.gif) |
Front yard mechanic |
Dec 22 2024, 05:09 PM
Senior Member Group: Members Posts: 1,241 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
I have a ford v10 out of 2 ton truck you can have to try and fit
SirAndy |
Dec 22 2024, 05:28 PM
Resident German Group: Admin Posts: 41,939 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
IIRC..... it won't fit. The engine is too wide to fit between the trailing arm mounts. It's been a long time but i remember Jason looked into this and there were clearance problems with the rear trailing arm mounts. (IMG:style_emoticons/default/popcorn[1].gif) |
technicalninja |
Dec 22 2024, 06:06 PM
@SirAndy .
Check that link out. You are a poster in it. It has pics near the end that do show "how much room" and even the coils installed actually fit. I've seen mention in a couple of other threads of having to fit remote mount coils. I prefer remote coils anyway. Keeping electrical stuff cool never hurts longevity. The pics Shiver posted were from the very end of that thread and it's swapped to a 3.2 S. He stated that the original 5 speed had "too short" gearing and he swapped in a 2.7 5 speed. I also thought that 400K "Singer style" 914 used the water-cooled drive package. The fit is TIGHT but doable IMO. Even looks like enough room for additional stiffening of the suspension ear. |
Lo-Fi Version | Time is now: 22nd December 2024 - 06:07 PM |
