> Headlight mystery
Shredhead
post Jan 9 2025, 10:08 AM
I've played around with cheap off-the-shelf LED headlight bulbs and found one that works. Kinda. Right now the low beams will not come on unless I have the fog lights on. Any ideas what that would be? 74 2.0.
Replies(1 - 5)
Literati914
post Jan 9 2025, 11:57 AM
More details? Did you touch any of the wiring at the light switch? Did you replace the stock flasher relay with an LED compatible relay?
Also, see if the condition changes as you scroll the brightness left to right at the light switch knob. I kind of have this issue.. where I'm only getting fogs when the light switch knob is all the way to the right (and it's a little sensitive at that).
post Jan 9 2025, 02:15 PM
Resident German
The bulbs probably don't draw enough current.
Cairo94507
post Jan 9 2025, 03:12 PM
Michael
Here is the simple solution: https://vintagecarleds.com/shop/7-inch/vc50...ate-7-inch-kit/
I have the flat lens Hella LED kit in my car and they are terrific. No issues at all, they just work. (IMG:style_emoticons/default/beerchug.gif)
JeffBowlsby
post Jan 9 2025, 05:49 PM
914 Wiring Harnesses
You might need to do this simple wiring mod for the LED headlights/flasher issue.
http://www.914world.com/bbs2/index.php?sho...4737&st=100
Shredhead
post Jan 12 2025, 11:53 AM
QUOTE(JeffBowlsby @ Jan 9 2025, 06:49 PM) *
Jeff, are you talking about Spoke's suggestion to cut the blue/white fog wire and ground it, bypassing the relay? I like that idea.
- Lo-Fi Version Time is now: 5th February 2025 - 08:59 AM
