> Shift rod balls, How do I get those installed
PaIsa
post Jan 11 2025, 03:22 PM
I got most of the material I ordered so I started to install some of the goodies.
We tried to get the shift rod balls on the shift rod just after the fire wall, without any success. I know someone said to heat them. I tried using boiling water, no success. I will try with heating the ball and freezing the steel part.
Any other suggestion. These balls are hard and tricky to get aligned straight.
Again open for any advice.
Thanks
Replies(1 - 3)
r_towle
post Jan 11 2025, 08:55 PM
Custom Member
Post a pic
I have not needed to use heat or cold….so I’m lost on which ones you are fighting with.
bdstone914
post Jan 11 2025, 09:29 PM
bdstone914
Not clear as to what you are asking. Is this a tail shift or side shift? A picture will help.
r_towle
post Jan 11 2025, 10:14 PM
Custom Member
Maybe it’s a tail shifter?
The cup bushings pop onto the balls with a firm smack from a hammer.
If you are doing it with the motor in, maybe a pry bar or a reversed clamp to press it on.
They do fit
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 12th January 2025 - 09:16 AM
