> Center Console Gauge Relocation, Removing Center Console
STL914
post Jan 13 2025, 04:40 PM
One of the items on my To Do List is to remove the center console installed by the PO from my '72 to get back to the original open look. I do however want to keep the oil temp and volt gauges, don't need the clock.
My question is whether or not the existing center console harness will be long enough to reach the gauges relocated to where the ashtray is/was located?
Replies(1 - 11)
Montreal914
post Jan 13 2025, 05:25 PM
QUOTE(STL914 @ Jan 13 2025, 02:40 PM) *
One of the items on my To Do List is to remove the center console installed by the PO from my '72 to get back to the original open look. I do however want to keep the oil pressure and volt gauges, don't need the clock.
No, but you can simply make extensions. (IMG:style_emoticons/default/confused24.gif)
dtmehall
post Jan 13 2025, 06:17 PM
you could buy vdo gauges and mount for under dash mounting
https://vdo-instruments.com/product/1-gauge...-2-1-16-gauges/
JamesM
post Jan 13 2025, 08:45 PM
Not sure exactly where you plan on putting them but remember that the factory gauges are 60mm and all the modern VDO gauges and mounting solutions for them are 52mm.
You have to get a little creative to relocate the stock 60s
FlacaProductions
post Jan 13 2025, 08:49 PM
I'd talk to John Bell and have him make up a combo gauge for your liking. Top notch work.
dtmehall
post Jan 13 2025, 08:54 PM
I added them directly in line with the old center console, fastened into the steel bottom of the dash.
i hope you can see this link of a comparable install
http://forums.pelicanparts.com/uploads/Gauges12.JPG
and yes, you would need new vdo gauges, but it beats butchering you upper dash to put in gauges.
btw, no mods are required to the dash, other that drilling holes into steel that is unseen
Ruff914
post Jan 14 2025, 10:30 AM
ARuff
I removed my Center Console because I found the gauges were too low and I had to glance downward to see them. This caused me to loose a main bearing in a race as my Accusump did not turn on with the ignition as I designed it to, so I lost oil pressure in a corner.
Adding holes for 4 gauges at eye level allowed me to have 2" gauges for Oil Pressure, Oil Temperature, Volts, and Fuel Pressure. I found my engine cuts out when fuel level is low and I'm in a tight corner.
This mod eliminates the Ash Tray (so what). I had to chop up the dash, kinda refit it to the right glove compartment side. I just shaped a piece of Balsa Wood to fill in over the gauges. Good enough for a race car. Could be made a whole lot nicer. For the gauge plate I had a local sheet metal guy make me from a cardboard template.
Now I don't miss critical oil and gas level problems on the fly.Attached Image
FlacaProductions
post Jan 14 2025, 11:05 AM
Per my @JBell suggestion - this is the one he did for me. the only thing "missing" now in relation to the gauges in the console is voltage. Well, and CHT but I have Johns gauge AND a console so I have 'em all. (clock, CHT, voltage in the console)
Geezer914
post Jan 14 2025, 03:22 PM
Geezer914
There are a couple of posts where owners mounted them in place of the ash tray
windforfun
post Jan 14 2025, 04:56 PM
Somebody needs to make a heads-up display for these cars.
(IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/idea.gif)
GregAmy
post Jan 14 2025, 08:07 PM
I'm old skool and removed the center console entirely and added some LEDs for better condition visibility.
Red = oil pressure because red should be for oil pressure
Orange = GEN light
Blue = high beams on
Green = turn signals flashing
bkrantz
post Jan 14 2025, 09:10 PM
My race car had oil temp and pressure mounted in the radio dash opening. The first version used a flat piece of aluminum sheet. For the second version, I worked some sheet steel to tilt each gauge towards the driver.
- Lo-Fi Version Time is now: 5th February 2025 - 08:50 AM
