70-914-6 Clean Up, All Original - going to keep it that way |
ctc911ctc |
Feb 4 2025, 09:19 AM
Senior Member Group: Members Posts: 973 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
1970, 914-6, 93K miles - excellent shape, very minor rust
I will post to this thread occasionally as I move through this project, I have asked for guidance and received many good thoughts from this team - thank you 914World I am in the midst of removing the engine and transmission. All original. There is oil everywhere, not flowing but seeping - seems that the valve covers are not tightened or have loosened with age. Here are the first pics: On the rack - hopefully not for long: Shift Assembly is very clean, no wear, bushings are in good shape but all of them will be replaced Heat exchangers have no holes in the pipes that I could find, the surrounding tin has been treated with anti-rust leakage - perhaps this was the plan in Stuttgart? No plans to change the exhaust system - any guidance as to cleaning or preservation? All comments and guidance appreciated - engine coming down on Friday |
DennisV |
Feb 4 2025, 09:37 AM
Senior Member Group: Members Posts: 590 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California |
1970, 914-6, 93K miles - excellent shape, very minor rust All comments and guidance appreciated - engine coming down on Friday Nice example. Thanks for sharing. You might consider a jack adapter for safely removing the engine. There are a variety of home made ways to do it. I am going to buy this when it comes time to install our freshly rebuilt engine. |
ctc911ctc |
Feb 4 2025, 10:59 AM
Great minds.................. (IMG:style_emoticons/default/biggrin.gif)
It arrives on Friday from Pelican, that is why the drop is on Friday! 1970, 914-6, 93K miles - excellent shape, very minor rust All comments and guidance appreciated - engine coming down on Friday Nice example. Thanks for sharing. You might consider a jack adapter for safely removing the engine. There are a variety of home made ways to do it. I am going to buy this when it comes time to install our freshly rebuilt engine. |
mb911 |
Feb 4 2025, 11:17 AM
914 Guru Group: Members Posts: 7,473 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
1970, 914-6, 93K miles - excellent shape, very minor rust I will post to this thread occasionally as I move through this project, I have asked for guidance and received many good thoughts from this team - thank you 914World I am in the midst of removing the engine and transmission. All original. There is oil everywhere, not flowing but seeping - seems that the valve covers are not tightened or have loosened with age. Here are the first pics: On the rack - hopefully not for long: Shift Assembly is very clean, no wear, bushings are in good shape but all of them will be replaced Heat exchangers have no holes in the pipes that I could find, the surrounding tin has been treated with anti-rust leakage - perhaps this was the plan in Stuttgart? No plans to change the exhaust system - any guidance as to cleaning or preservation? All comments and guidance appreciated - engine coming down on Friday I have refurbished many original heat exchangers. I like to treat with Ospho then clean very well and paint with high heat gray primer. Works well |
ctc911ctc |
Feb 4 2025, 11:29 AM
powder coat?
[/quote] I have refurbished many original heat exchangers. I like to treat with Ospho then clean very well and paint with high heat gray primer. Works well [/quote] |
DennisV |
Feb 4 2025, 02:22 PM
Great minds.................. (IMG:style_emoticons/default/biggrin.gif) It arrives on Friday from Pelican, that is why the drop is on Friday! Please post a follow up and let us know what you think of the adapter. |
Cairo94507 |
Feb 4 2025, 02:51 PM
Michael Group: Members Posts: 10,204 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
If you are interested in doing more than Ben suggested, consider ceramic coating. But, I thinks Ben's suggestion is sound advise. (IMG:style_emoticons/default/beerchug.gif)
ctc911ctc |
Feb 4 2025, 03:19 PM
I found a very good powder coat shop here in the Boston area - they did all of my 2.0L engine tin as well as various other components.
I was going to have them do the engine tin as well as have them look at the heat exchangers, factory gray is a good idea - any more advice? Ceramic Gray? If you are interested in doing more than Ben suggested, consider ceramic coating. But, I thinks Ben's suggestion is sound advise. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 5th February 2025 - 03:48 AM |
