914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,083 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Thought I would post this up. From what I am seeing, the VW bus 100mm CV should be a direct bolt on with NO machining on stock 914 shaft like the 944 CV requires Should work with 911SC flanges and stub axle. The 17 degree angle should have NO bearing on stock use since 914 is 12 degrees.
Click to open chart. Attached thumbnail(s) ![]() ![]() ![]() ![]() ![]() |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,744 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
I used bus axles when I narrowed a set of trailing arms 1" each side..
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,926 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
Great information, thank you for posting
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,623 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
Who sells the bus 100mm CVs ? And, do they require any further modification to replace a 914 CV ?
thomasotten |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,564 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 ![]() |
I thought the Bus CV's required different flanges at the transmission?
914Sixer |
Thomas,
They do require 915 transmission 100mm coarse spline flanges. |
Lo-Fi Version | Time is now: 26th February 2025 - 01:29 PM |
