> 914World Classifieds Rules
> WTB Dan Gurney Style lug nuts w/ Washers
Cfletch
post Feb 23 2025, 10:26 PM
Hey there, recently found a set of 5 lug Dan Gurney style wheels that require specific flat bottom nuts with a washer, looking for a source on these. Will need 20 of course.
Replies(1 - 7)
TheCabinetmaker
post Feb 23 2025, 10:34 PM
I drive my car everyday
Good luck with your search. They've been nla for years.
Might look on the samba
mjrrti
post Feb 24 2025, 12:56 AM
High Desert Member
QUOTE(Cfletch @ Feb 23 2025, 08:26 PM) *
Check lugnutking.com I bought some after market nuts from him at Pomona swap meet a while back. I bet he can get them. I am pretty sure Empi still sells a stud kit that gives you 1/2” studs that screw into your hubs so you can use standard thread lug nuts. I have Gurneys and that lug nut set up on 1 of my cars.
mjrrti
post Feb 24 2025, 01:01 AM
High Desert Member
I did not catch that you have 5 lug until I read your wtb again. Mine are 4 lug not 5. I would still check though. He had a ton of stuff at Pomona. I think one of the pictures on his website is Pomona.
Cfletch
post Feb 24 2025, 01:22 PM
I'll give that website a shot and see if they have anything I can use! Thanks for a lead!
GaroldShaffer
post Feb 24 2025, 09:58 PM
You bought another 914?
I'm pretty sure these are not what you need, but I could be wrong. I have had these for years. Not sure what rims they came with anymore. (IMG:style_emoticons/default/confused24.gif)
Only have 10 complete and 6 without the threaded part.
Cfletch
post Feb 25 2025, 11:37 AM
Sadly, not sure if that will work for me. That is generally the idea with these wheels, but they are going on 911 hubs with studs. I think the above would work well on 914 stock hubs since they accept a threaded bolt vs my pressed in studs. I'm trying to find basically 14x1.5 nuts with that shoulder and washer and not wanting to switch out the studs so that I can use different wheels at another point down the road
rgalla9146
post Feb 25 2025, 04:44 PM
I had the same issue with vintage Minilites
I have a full set of new 14 x 1.5 shouldered lugs with proper thickness washers.
The sleeve is 18.75 mm diameter x 22mm reach with 4mm washer in place.
Includes a spare so actually 21 lugs, 21 washers.
$ 150. plus ship
Rory
- Lo-Fi Version Time is now: 26th February 2025 - 01:33 PM
