NARP74 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,338 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains ![]() |
So my 2.0 has had a hard life, several owners, many changes. Repaired or replaced body panels, repainting, making it as unoriginal as possible. Right now, everything is black, murdered out before that was cool.
Controversy begins here... I don't like original side mirrors. Don't like the chrome, the shape, anything about them. The car came with baby tornado mirrors which elicit disdain among most of the community which I don't understand. I am not a huge fan of them, but they are installed, and badly at that. So I was thinking of a change but not sure what alternatives exist that are not the two already mentioned. Is it either or? One issue I have with the current setup is that they just used sheet metal screws through the door skin to attach the tornado mirrors. They get loose all the time and bounce around, that is a negative. I looked inside and it appears the original threaded metal mounts are intact but they might have had the top of the hole worked or covered. So if I went back to stock I would have to fill the sheet metal screws that would probably be visible and then drill the original holes out. I am trying to balance practicality with desire at this point. This car is not worth lots of metal work and door painting at this point. Should I leave it as is and move on to other items? Tons on the work list. I am on the doors now so it is in scope. |
chmillman |
Member ![]() ![]() Group: Members Posts: 67 Joined: 15-June 24 From: Switzerland Member No.: 28,183 Region Association: Europe ![]() ![]() |
If you have the inner door panel off, you could replace the existing sheet metal screws with machine screws and washers/locknuts. Shouldn’t loosen up after that…
emerygt350 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,609 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States ![]() |
Just count yourself lucky you don't have the full on 31330 style. I think they were only on Alpha spiders and ferrari's. 400 dollars a pop if you are lucky. I took out a deer's head with my passenger mirror. Took forever to find one and even then it was in pretty rough. Better than the deer killer though.
targa72e |
Member ![]() ![]() Group: Members Posts: 283 Joined: 11-September 16 From: colorado Member No.: 20,392 Region Association: None ![]() ![]() |
I think 911 flag mirror don't look bad on the right car. Plentiful and not that expensive. There are post on how to install them on a 914.
![]() I have a loose set if you want to see them up close. john |
theer |
Senior Member ![]() ![]() ![]() Group: Members Posts: 689 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States ![]() ![]() |
Someone here used early Miata mirrors. Can’t find a picture, but they looked good. And they’re plentiful.
NARP74 |
Thanks John.
I'll look at the Miata mirrors. Maybe if I could get the original mirrors in black chrome. How does that process work? |
East coaster |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,817 Joined: 28-March 03 From: Millville, NJ Member No.: 487 Region Association: None ![]() ![]() |
NARP74 |
Those look good with the flares too. Nice car.
technicalninja |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,445 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
Those ae the later NB2 mirrors. 2001-2005
BillJ |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,267 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None ![]() ![]() |
I have the baby tornadoes as well and they work fine and I like them. I am in process of cerakote finishing all the trim a nice black so that is an option if you want to go originals. My $0.02 is secure the ones you have with bolts that don't work loose and enjoy the car. If you like them who cares what others think? It's not like 914 crew is wine and cheese snobs scene anyway (I like wine and cheese but keep the snobbery on the down low).
NARP74 |
I like the nut and bolt suggestion from those that mentioned it, an easy fix for now.
@BillJ tell me about the cerakote trim process. |
Lo-Fi Version | Time is now: 26th February 2025 - 01:34 PM |
