Steve1956 |
Newbie ![]() Group: Members Posts: 24 Joined: 4-November 22 From: Morocco,Indiana Member No.: 26,966 Region Association: None ![]() |
Hello,I am working on installing shift cables from a'97 Boxster.Any ideas on how to clamp the body of the cable ends? I cut the socket heads off and managed to thread the cable end with an M6 so I can use removable Heim joints.I have pictures of another member's brackets so that isn't the question. The first thing that came to mind were these clamp blocks for shaft supports.When I worked as a tool maker,I made many of these for different applications but I don't have access to a milling machine anymore.
Any ideas?The bore needs to be 28mm ![]() ![]() |
tygaboy |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,542 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California ![]() ![]() |
I'd take a look at the Boxster cable mount bracket and repurpose it. It's a pretty simple stamped part that could be cut/welded to suit your needs. Nice thing then is its factory clips to hold the cable(s) in place.
Just my $0.02. Attached image(s) ![]() |
Steve1956 |
Thanks a bunch,I never considered that. I own a lathe but it's in storage right now.I have 47 years experience as a toolmaker and I know what to do but don't have all the machinery! I like the idea of stock parts.
thanks so much. |
Chris914n6 |
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,455 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region ![]() |
Don't mount it vertical. Keep it flat like the other and make a pivot arm. Or something as simple as a sliding wedge would work.
Steve1956 |
I'd take a look at the Boxster cable mount bracket and repurpose it. It's a pretty simple stamped part that could be cut/welded to suit your needs. Nice thing then is its factory clips to hold the cable(s) in place. Just my $0.02. I looked at these brackets,they range from $88-$109,pretty pricey for a piece of stamped steel. Couldn't find any used ones yet. |
Steve1956 |
Steve1956 |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,225 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
I just used a Boxster transmission. Hooking up the cables was easy.......
gnomefabtech |
Member ![]() ![]() Group: Members Posts: 146 Joined: 27-December 22 From: Los Angeles Member No.: 27,063 Region Association: None ![]() |
ClayPerrine |
I just used a Boxster transmission. Hooking up the cables was easy....... Great solution, that Boxster trans. How do you adapt to that trans? CVs? Anyhow, here are some pictures of my cable shift setup. I added an extension onto the shifter console casting. ![]() ![]() ![]() There is a whole thread on my build. The info on the transmission starts here: http://www.914world.com/bbs2/index.php?sho...79084&st=80 |
Steve1956 |
Great setup! Rear trans mount and CV axles?
gnomefabtech |
Wow. Reversing the starter mount. Nice!
ClayPerrine |
Great setup! Rear trans mount and CV axles? The rear trans mount is custom made. Some people make a mount that doesn't go around the back end of the transmission. I don't like a cantilevered mount, so I made sure we built a mount that was supported on both sides. The nice part is that I can add the mounting brackets for the wheel speed sensors to it that I need for traction control. The axles are for a 991. They fit the hubs and use the same sized CV joint as the Cayman. |
ClayPerrine |
Wow. Reversing the starter mount. Nice! I moved the starter to the other side to provide access to the crankshaft position sensor. Rather than pull the whole transmission to replace the sensor, all I have to do is pull the starter. I actually do try to think of things like that! (IMG:style_emoticons/default/biggrin.gif) |
Steve1956 |
Wow. Reversing the starter mount. Nice! I moved the starter to the other side to provide access to the crankshaft position sensor. Rather than pull the whole transmission to replace the sensor, all I have to do is pull the starter. I actually do try to think of things like that! (IMG:style_emoticons/default/biggrin.gif) My engine is a 3.1lt GM V6,had to move the alternator down and to the driver side because it hit the firewall in the original location but now it blocks the shift rod. so hence the cable shifter. |
Lo-Fi Version | Time is now: 3rd April 2025 - 06:04 PM |
