flxzcat |
Newbie ![]() Group: Members Posts: 24 Joined: 13-June 11 From: lake forest socal Member No.: 13,188 Region Association: None ![]() |
Here is the problem, I will need to make my own spacer from a 21mm split dowel pin that is 40mm long, so I will need to machine the dowel pin to length using my mill with a parting tool in the vise.
Can someone please tell me how long the original pilot bearing crank shaft split spacer #022.105.159 is? 8mm, 10mm or other? |
L-Jet914 |
Member ![]() ![]() Group: Members Posts: 317 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California ![]() |
@Jake Raby I believe has a bunch of these. Hopefully he can measure one for you.
Lo-Fi Version | Time is now: 12th March 2025 - 09:27 AM |
