worn |
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,447 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
Hi Folks,
I need a new front latch for my targa top. New seals and first time going out of the shop under power. Great thing to do, but the fit was too stiff with new seals and the handle broke away in my hand just as the latch seater. Tempted to cast some in aluminum, or machine one, but don’t really need that project. Thanks. Also I need a charcoal canister. This is a ‘76 and I have routed a new vapor line, but lack the canister. Thanks again. |
GaroldShaffer |
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,628 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None ![]() ![]() ![]() |
PM sent
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,797 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Hi Folks, I need a new front latch for my targa top. New seals and first time going out of the shop under power. Great thing to do, but the fit was too stiff with new seals and the handle broke away in my hand just as the latch seater. Tempted to cast some in aluminum, or machine one, but don’t really need that project. Thanks. Also I need a charcoal canister. This is a ‘76 and I have routed a new vapor line, but lack the canister. Thanks again. I think Auto Atlanta and Uro make the handles. I restore the latches but many I have are with broken handles. They should have been cast in metal. I should have an extra charcoal canister. Where are you mounting it? 75-76 had them mounted to the battery tray. 74 had them mounted to the rear firewall. |
worn |
worn |
Hi Folks, I need a new front latch for my targa top. New seals and first time going out of the shop under power. Great thing to do, but the fit was too stiff with new seals and the handle broke away in my hand just as the latch seater. Tempted to cast some in aluminum, or machine one, but don’t really need that project. Thanks. Also I need a charcoal canister. This is a ‘76 and I have routed a new vapor line, but lack the canister. Thanks again. I think Auto Atlanta and Uro make the handles. I restore the latches but many I have are with broken handles. They should have been cast in metal. I should have an extra charcoal canister. Where are you mounting it? 75-76 had them mounted to the battery tray. 74 had them mounted to the rear firewall. Thanks Bruce. Garold helped me already. The handles should have been made out of aluminum in my view, which is dim sometimes I have to admit. |
Lo-Fi Version | Time is now: 12th March 2025 - 09:45 AM |
