> Engine Cooling Fan, Does no one make aftermarket replacements?
Vicious
post Mar 26 2025, 10:15 PM
The engine cooling fan on the motor that came with my car has several broken fins/blades. Looking for a replacement i can only seem to find used part? Does no one produce oem style or aftermarket replacements for this? Is used my only option?
Sorry if this has been covered. Did not find anything in the search.
Replies(1 - 19)
914werke
post Mar 26 2025, 10:21 PM
Whats the problem with a solid OE pre-owned part?
Hate to break it to you but many if not most repop's aren't = quality to their originals !
To your Q: no Ive never seen a new impeller.
Vicious
post Mar 26 2025, 10:31 PM
QUOTE(914werke @ Mar 26 2025, 11:21 PM) *
No problem with pre-owned, just typically opt to go new if it's available.
Dave_Darling
post Mar 27 2025, 06:36 PM
914 Idiot
Not enough money in it to make new fans IMHO. Used ones are available, often for a reasonable amount of money. Just make sure not to get the "lightweight racing fan", because you already have one of those--it's a fan with blades broken off.
--DD
Vicious
post Mar 27 2025, 07:50 PM
QUOTE(Dave_Darling @ Mar 27 2025, 07:36 PM) *
--DD
Got a good chuckle out of that, thank you
JamesM
post Mar 27 2025, 11:00 PM
QUOTE(Vicious @ Mar 27 2025, 05:50 PM) *
--DD
Would be funnier if it were a joke. People actually sell them like this.
mgphoto
post Mar 28 2025, 10:19 AM
"If there is a mistake it will find me"
Going back to the Porsche Panorama June 1973, the winning Elliot Forbes Robinson E Production car used a fan with all of the fins removed, except for the four that had the bolts holding the fan belt ring.
Used fan not an issue but you need to find one with the correct timing marks for your engine.
brant
post Mar 28 2025, 11:04 AM
No blades is a good way to get no cooling for your heads
Probably ok if you rebuild the motor every weekend
Root_Werks
post Mar 28 2025, 11:34 AM
Village Idiot
Here's a used one, couldn't tell you if it'd work on your 914 or not:
https://www.thesamba.com/vw/classifieds/det....php?id=1963112
GregAmy
post Mar 28 2025, 11:45 AM
If $299 is the going price for a good used one then I bet a lot of them will come out of the woodwork. Like the one sitting on the shelf in my garage attic storage.
cholland_
post Mar 28 2025, 01:29 PM
I've got one I've been trying to sell for about three years for $50 with no takers. Mine's even been blasted and repainted.
technicalninja
post Mar 28 2025, 04:04 PM
Verify timing marks.
My 75 1.8 fan has a single mark only at base timing of 7-8. It did not have either the TDC mark OR the total timing mark of 27-30.
The 73 2.0L fan I replaced it with had TDC white and total timing red.
You need the TDC mark for leak down testing.
Using a flexible dress tape measure 1/2 way round both directions (splint difference) and make a 2nd TDC mark for the opposing cylinders.
Root_Werks
post Mar 28 2025, 05:01 PM
Village Idiot
QUOTE(cholland_ @ Mar 28 2025, 12:29 PM) *
@Vicious
There you go!
Vicious
post Mar 28 2025, 07:03 PM
QUOTE(cholland_ @ Mar 28 2025, 02:29 PM) *
If it's the right one for me I'll send you tonight. Sending you a message.
Vicious
post Mar 28 2025, 07:04 PM
QUOTE(Vicious @ Mar 28 2025, 08:03 PM) *
If it's the right one for me I'll send you money tonight. Sending you a message.
Dave_Darling
post Mar 29 2025, 04:23 AM
914 Idiot
QUOTE(brant @ Mar 28 2025, 09:04 AM) *
Or if you have a VERY VERY LARGE duct (I dubbed it a "sewer pipe") feeding cold air directly from the headlight buckets straight through the car to the fan inlet. Quite a few 914-4 racers used to do that, to take advantage of a rule written for the LBCs (Little British Cars) that allowed cooling air to be ducted in from the headlight buckets.
IIRC, the cars that ran that way would rebuild about once per season. Assuming they didn't have to spend any real time at a stop or at very low speeds.
--DD
GregAmy
post Mar 29 2025, 05:19 AM
QUOTE(Dave_Darling @ Mar 29 2025, 05:23 AM) *
I'm guessing SCCA Club racers still had some fandage going on. After all, Ginther had Porsche money, club racers do not...Chris Foley would know, I think he came up with that idea back in the 90s. His F Production race car (still for sale) has it. - GA
Dave_Darling
post Mar 29 2025, 02:33 PM
914 Idiot
QUOTE(JamesM @ Mar 27 2025, 09:00 PM) *
Not to name names or anything, but an ebay search might turn up a certain business selling "lightweight racing fans" that are just normal fans with a blade or two broken off here and there. I suppose they get more money for those than if they more truthfully listed them as "partly functional fans, missing some blades".
--DD
Artfrombama
post Mar 29 2025, 06:08 PM
Whatever fan you source, would be wise to check #1TDC with a dial indicator to verify the notches on the fan/shroud are correct.My $.02
Vicious
post Mar 29 2025, 08:26 PM
QUOTE(Artfrombama @ Mar 29 2025, 07:08 PM) *
Looks like I'm making a deal for a very nicely restored family from cholland that has no indicator marks on it so will need to do that either way. That will require some more research. By the time this cars on the road I'm sure i will have annoyed at least half the forum with my constant questions
- Lo-Fi Version Time is now: 2nd April 2025 - 05:49 PM
