> GT reinforcement kit from Otto's, Maybe early members remember...
Montreal914
post Mar 30 2025, 09:11 PM
I came across this GT reinforcement that was made many years ago by John Williamson (RIP), owner of Otto's in Venice.
I am wondering if anyone here is familiar with it? Maybe they have this kit on their car? (IMG:style_emoticons/default/driving.gif)
I have figured out where four out of the six panels go, but I am puzzled as for the last two.
Where would part 1 and 2 go? (IMG:style_emoticons/default/confused24.gif)
Thanks! (IMG:style_emoticons/default/smilie_pokal.gif)
Replies(1 - 15)
Maltese Falcon
post Mar 30 2025, 09:22 PM
On the 4cyl cars with the Left and Right engine mount buckets...you probably don't use some of the pieces; but I will check with one of my buds that worked with JW at that (former) Venice shop.
Maltese Falcon
post Mar 30 2025, 09:52 PM
This is the Mad Dog kit that my bud sells today.
We are thinking that your Otto's kit might have been an 'Automotion copy...and those 2 pieces might have gone on to the 9146 bulkhead motor mount for stiffening.
campbellcj
post Mar 31 2025, 07:53 AM
I can't Re Member
JW did my car with that "armor plating" kit as he called it - I'll try to take a look/pic
Steve
post Mar 31 2025, 08:09 AM
I also have Otto’s kit on my car. I have the original instructions. I can look tonight for them when I get back home.
Montreal914
post Mar 31 2025, 08:13 AM
(IMG:style_emoticons/default/smilie_pokal.gif) This forum and group of people is simply awesome! (IMG:style_emoticons/default/pray.gif)
Looking at pictures, I wonder if number two could be for here... (IMG:style_emoticons/default/confused24.gif) Looks like we will know soon enough! (IMG:style_emoticons/default/smile.gif)
campbellcj
post Apr 1 2025, 06:43 PM
I can't Re Member
Here are a few awful pics - car is in a pretty tight space (and grungy too)
campbellcj
I can't Re Member
more
live free & drive
post Apr 1 2025, 10:01 PM
QUOTE(Montreal914 @ Mar 30 2025, 09:11 PM) *
The #2 piece may be the Ralph Meaney motor mount reinforcement strap - it is on the motor side mount and wraps over/around the tube that the big main bolt goes though (a known weak spot of the GT racers)
sixnotfour
post Apr 2 2025, 10:53 AM
930cabman
post Apr 2 2025, 12:59 PM
QUOTE(Steve @ Mar 31 2025, 08:09 AM) *
Please share if you are able, I just purchased a set of these from a guy on the bird. Mostly self explanatory, but instructions are often helpful
thank you
Montreal914
post Apr 2 2025, 11:47 PM
So, it looks like a couple of options for part 2:
- reinforcement for the /6 mount per Marty and Live Free
- replacement for the missing layer when /4 mounts are removed from sixnotfour.
Or could part #1 be the /6 mount reinforcement? Then part 2 would be for when the /4 mounts are removed, per Live Free's picture of that area? I guess that would go right in line with Marty's comment, part 2 not needed if /4 mounts are kept on the car.
Thank you Chris for the installed pictures. These are from Otto's kit?
Looking forward to seeing Steve's input (install sheets). (IMG:style_emoticons/default/smile.gif)
Steve
post Apr 3 2025, 08:19 AM
@montreal914
It’s a miracle I found it. Pretty crude, but this is what came with the kit.
Montreal914
post Apr 3 2025, 08:47 AM
@Steve Thank you for finding this! (IMG:style_emoticons/default/smilie_pokal.gif)
So, what I am understanding from this is none of these two parts (my labeling as 1 and 2) labeled as 4a and 4b in Otto's sketch are for for any engine mount reinforcement. We can set that theory aside.
It looks like 4a - 4b are to reinforce the longs in the trailing arm mounting point area. The one I have labeled as 2 could be the underside along that indented area for the /4 mount (per Livefree's edit Sixnotfour picture), but I am not sure I can see where my labeled #1 would go.
I have to say I am not really understanding what the upper left portion of the drawing means...
Overal, this is definitely great progress! (IMG:style_emoticons/default/smile.gif)
More edits:
Then again, what are we looking at here in Chris' pictures? (IMG:style_emoticons/default/idea.gif)
Edit: I believe this one below is one of the two stock layers tying the inner to the outer consoles.
Steve
post Apr 3 2025, 09:10 AM
I know the shop in AZ that installed the kit 30 years ago was also confused by the instructions. They had to call JW to figure it out. I can put my car on the lift this weekend and take some pictures. The shop in AZ went out of business years ago.
Montreal914
post Apr 3 2025, 09:37 AM
Steve, when you have an opportunity, this would be great!
Looking again at Chris' first picture I circled in red, I may have a comparison below. I rotated my picture to get a similar angle. I think part #1 goes there, although the inner end may need attention. Compare the plug welds location on Chris' and the holes in my bare plate, looks promising. (IMG:style_emoticons/default/idea.gif)
Attached ImageAttached Image
- Lo-Fi Version Time is now: 3rd April 2025 - 06:03 PM
