> Vent Control Issue
friethmiller
post Mar 31 2025, 08:52 AM
I'm having an issue with my vent controls and since I have my gas tank out at the moment I though it would be a good time to address the problem. Currently, my defrost and floor settings work great but I can't seem to get any air out of my dash vents. Here's a pic of the control setup. Do I have something incorrectly connected? I remember following the instructions in thread a few years ago (yellow 914 pics). I'm thinking I might have switched the short and medium length controls. Not sure. Any assistance would be greatly appreciated (IMG:style_emoticons/default/beerchug.gif)
Replies(1 - 16)
friethmiller
post Mar 31 2025, 02:23 PM
So, could switching these two wires cause the dash vents not to work? (IMG:style_emoticons/default/idea.gif)
friethmiller
post Mar 31 2025, 02:51 PM
Using these as reference:
http://www.914world.com/bbs2/index.php?showtopic=86942
https://914electric.wordpress.com/2011/03/18/take-the-heat/
hndyhrr
post Mar 31 2025, 03:19 PM
I'm sure others will reply.
If you take off the Black Duct hoses you can see how the flaps inside work. I had to do this when I replaced cables.
oh and that back cable is a booger to get at.
friethmiller
post Mar 31 2025, 03:32 PM
Thanks @hndyhrr . Great idea. That way I can see what's going on currently before messing with it.
windforfun
post Mar 31 2025, 03:47 PM
I didn't realize you could still buy a brand new 914.
(IMG:style_emoticons/default/drooley.gif) (IMG:style_emoticons/default/drooley.gif) (IMG:style_emoticons/default/drooley.gif)
Front yard mechanic
post Mar 31 2025, 05:57 PM
QUOTE(windforfun @ Mar 31 2025, 01:47 PM) *
(IMG:style_emoticons/default/KMA.gif)
technicalninja
post Mar 31 2025, 06:44 PM
QUOTE(windforfun @ Mar 31 2025, 04:47 PM) *
You are correct!
You can't simply purchase a new 914.
Only way to get one is the hard way like Fred did.
This level of "new" is a bit masochistic IMO...
L-Jet914
post Mar 31 2025, 07:13 PM
I found this diagram in the FSM hope this helps.
friethmiller
post Mar 31 2025, 10:04 PM
After looking at everything, it seems to be assembled correctly. I think my problem is something else. If I have defrost then I should have dash vents since that smaller tube comes off the defrost plenum. Once I get the battery back in, I’ll test everything out for real.
bkrantz
post Apr 1 2025, 08:13 PM
Fred, here are a few photos from my installation 4 years ago.
bkrantz
post Apr 1 2025, 08:14 PM
Another
bkrantz
Another
bkrantz
post Apr 1 2025, 08:15 PM
Another
bkrantz
post Apr 1 2025, 08:16 PM
Another
bkrantz
Another
friethmiller
post Apr 1 2025, 09:04 PM
@bkrantz - Nice pics! Thank you. I can confirm that mine is routed just like yours. (IMG:style_emoticons/default/beerchug.gif) I don't think my vent issue is related to the pull wires. Since the vents work off the defrost pipe, and the defrost works, something must be blocked or closed as the air goes through the smaller hose, through the dash to the vent itself. Yes, I made sure the open/close lever at the top of the vent was open. I'll test it all out again once I reinstall the battery this weekend.
- Lo-Fi Version Time is now: 3rd April 2025 - 06:03 PM
