JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,872 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
What is seen cannot be unseen. (IMG:style_emoticons/default/confused24.gif)
https://www.beverlyhillscarclub.com/1974-po...ter-c-17295.htm Attached thumbnail(s) ![]() ![]() |
JeffBowlsby |
The peanut gallery can decide if this is even drivable as is from this underbody photo...geez...
NARP74 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,357 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains ![]() |
There is a reason the factory did certain things. Other reasons it might be undrivable, can't see a shift rod, no clutch cable, and no speedo cable. Must be a work in progress.
Got to keep up with those design changes. |
Maltese Falcon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,025 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None ![]() ![]() |
License plate frame speaks volumes.
JamesM |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,069 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
Didn't think it would even fit on the HEs. In factory form it shouldn't, flanges have different bolt locations. (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) Guessing they drilled the HEs or replaced the flanges completely as the factory 1.7 muffler has studs. |
bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,320 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
That 914 has far too much intact sheet metal for BHCC. (IMG:style_emoticons/default/screwy.gif)
KELTY360 |
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,119 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest ![]() ![]() |
License plate frame speaks volumes. Reminds me of a W.C. Fields quote, "I wouldn't to be a member of a club that would want me to join." (IMG:style_emoticons/default/evilgrin.gif) |
Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,799 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
KYB shocks are always a good indicator of a quality build! (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/barf.gif)
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,848 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
@JeffBowlsby
' date='Mar 31 2025, 03:27 PM' post='3198984'] The peanut gallery can decide if this is even drivable as is from this underbody photo...geez... [/quote] I thinkbthar muffler is a 1974 1 8 with the bolt on exhaust tip. But still how? I once went to a muffler shop called M & F Muffler. They told me it stood for "make it fit" They did. I think they welded the heat exchanger to the muffler.sinlet flange. Note the open hole in the HE flange. Kustom fit. A BHCC concour car. Gaskets? We don't need no stinken gaskets. Attached thumbnail(s) ![]() |
bdstone914 |
bdstone914 |
The peanut gallery can decide if this is even drivable as is from this underbody photo...geez... I think i will call them and ask if I can rest drive it. I should drive if I start in first gera and don't bother with that silly clutch pedal. I have done the before when I broke a clutch cable |
JeffBowlsby |
If thats true I am without words. Those SS HEs look new-ish...better to not have done anything rather than damage good parts.
JeffBowlsby |
A knowledgeable buyer should look this car over very carefully. It may not be a complete car, just a tub with some mismatched parts more or less attached to it.
I noticed the write up on it is copy pasted from their previous CS, which had brown interior and dual mirrors. This car does has neither but it does have the 75-76 door panels and who know what else. The dash gauges look nice. They do mention it is a non-running project car. |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,926 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
imagine the torque that must be twisting the head studs to get that muffler lined up.
JeffBowlsby |
That was what is puzzling. The 1.7/1.8 HE ends/muffler mounts are ~1.5 inches wider than the 2.0L HE ends/muffler mounts.
(IMG:style_emoticons/default/smash.gif) Attached image(s) ![]() |
Garland |
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,411 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest ![]() ![]() |
Wannabe trail dragger!
Garland |
(IMG:style_emoticons/default/welder.gif) Wannabe trail dragger!
sportlicherFahrer |
Nothing to see here. ![]() ![]() ![]() Group: Members Posts: 1,119 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest ![]() ![]() |
The peanut gallery can decide if this is even drivable as is from this underbody photo...geez... Best shifting 914 on the road with the new and improved WiFi shifter assembly! (IMG:style_emoticons/default/blink.gif) |
bdstone914 |
@JeffBowlsby
date='Apr 1 2025, 08:23 AM' post='3199116'] That was what is puzzling. The 1.7/1.8 HE ends/muffler mounts are ~1.5 inches wider than the 2.0L HE ends/muffler mounts. (IMG:style_emoticons/default/smash.gif) [/quote] Easy. Center the muffler over the heat exchangers. Ignore that nothing lines up. Weld muffler to heat exchangers. Wal la! Done. Zoom in on the pictures and you can see the heat exchanger flanges extending inward beyond the muffler flanges. |
bdstone914 |
Lo-Fi Version | Time is now: 3rd April 2025 - 06:03 PM |
