Sunday, 6 April 2025 |
Vicious |
Newbie ![]() Group: Members Posts: 37 Joined: 31-October 22 From: South Dakota, USA Member No.: 26,958 Region Association: Upper MidWest ![]() |
My fan shroud in some spots looks like it's separating. I'd like to fully seperate it and get it cleaned up and powder coated/ painted in and out. I don't see any fasteners holding it together though
Geezer914 |
Geezer914 ![]() ![]() ![]() Group: Members Posts: 1,893 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States ![]() ![]() |
Should be screws holding it together.
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,016 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,816 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
It's balanced so make some witness marks so it goes together the same way.
Vicious |
Should be screws holding it together. There was in fact no screws holding the shroud together. One of many things I've found that show me that the shop the previous owner had put this thing together were idiots. The alternator was the only thing holding this thing together. I will need to source some replacement screws while it's at the powder coater |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,927 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
maybe balancing it when you reassemble.
it rotates pretty high speed at high RPM worth doing. |
Vicious |
maybe balancing it when you reassemble. it rotates pretty high speed at high RPM worth doing. I was wondering about the balancing comment above. Now I'm realizing i must be using the wrong verbiage. This is the piece I'm talking about. The two halves were not fastened together and after removing the alternator were able to be separated. If anyone knows what the correct size fastener is I'd be very grateful. Attached thumbnail(s) ![]() |
Ron914 |
Member ![]() ![]() Group: Members Posts: 197 Joined: 19-April 22 From: Huntington Beach,Ca Member No.: 26,487 Region Association: Southern California ![]() ![]() |
maybe balancing it when you reassemble. it rotates pretty high speed at high RPM worth doing. I was wondering about the balancing comment above. Now I'm realizing i must be using the wrong verbiage. This is the piece I'm talking about. The two halves were not fastened together and after removing the alternator were able to be separated. If anyone knows what the correct size fastener is I'd be very grateful. I was wondering about the comments on this ,only the fan wheel itself turns certainly the shroud doesn't rotate . |
Ron914 |
maybe balancing it when you reassemble. it rotates pretty high speed at high RPM worth doing. I was wondering about the balancing comment above. Now I'm realizing i must be using the wrong verbiage. This is the piece I'm talking about. The two halves were not fastened together and after removing the alternator were able to be separated. If anyone knows what the correct size fastener is I'd be very grateful. I was wondering about the comments on this ,only the fan wheel itself turns certainly the shroud doesn't rotate . While working on my motor during reassembly I tried to split the halves of the shroud but it didn't bug so I decided leave it alone before I break it. |
bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,325 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
maybe balancing it when you reassemble. it rotates pretty high speed at high RPM worth doing. I was wondering about the balancing comment above. Now I'm realizing i must be using the wrong verbiage. This is the piece I'm talking about. The two halves were not fastened together and after removing the alternator were able to be separated. If anyone knows what the correct size fastener is I'd be very grateful. Off the top of my head, it uses a couple of different thread sizes and lengths. I replaced the stock bolts with stainless Allen heads. |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,851 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Should be screws holding it together. There was in fact no screws holding the shroud together. One of many things I've found that show me that the shop the previous owner had put this thing together were idiots. The alternator was the only thing holding this thing together. I will need to source some replacement screws while it's at the powder coater Look up the sizes in PET. Several 6mm by about 30mm and a few 8mm hex bolts |
Vicious |
Should be screws holding it together. There was in fact no screws holding the shroud together. One of many things I've found that show me that the shop the previous owner had put this thing together were idiots. The alternator was the only thing holding this thing together. I will need to source some replacement screws while it's at the powder coater Look up the sizes in PET. Several 6mm by about 30mm and a few 8mm hex bolts I'm sorry but still A LOT i don't know...what is PET? |
JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,878 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,763 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
I've got them, hit me up and I'll drop them in the mail.
brant |
My mistake
Misunderstood |
Vicious |
73-914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 610 Joined: 24-April 10 From: Albany UpstateNY Member No.: 11,651 Region Association: None ![]() ![]() |
It's balanced so make some witness marks so it goes together the same way. (IMG:style_emoticons/default/screwy.gif) |
mgphoto |
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,374 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California ![]() |
Fan needs to be balanced, if you take it apart, not the shroud, I needed to take mine apart to clean the grease out of it before powder coating. A bit tough to separate but it can be done.
Lo-Fi Version | Time is now: 6th April 2025 - 01:53 PM |
