Squealing Brakes, Can trapped air cause it? |
Allan |
Sep 1 2005, 07:45 AM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Took my car out yesterday and actually drove it to the office and to run some errands. After about 4 or 5 miles I started to get a high pitched squeal from the left rear brake when I applied moderate pressure and it goes away if I press harder or let off. I'm sure that there is still some air in the system and am wondering if that can cause it.
I'm going to re-bleed the brakes this weekend. |
ArtechnikA |
Sep 1 2005, 07:50 AM
no. probably just a glazed pad. when you're comfortable with their performance overall, do a series of relatively firm stops from ~60->20. you need to work the brakes to wear off/through the glaze. they should be hot but you should not work them to failure. then see if that helps. if not, check to make sure that all the brake hardware is in place and working, especially the spreader spring. what lind of pads ? |
URY914 |
Sep 1 2005, 07:51 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,359 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
The squeal comes from the pads vibrating on the rotor or against the piston, not from air in the system.
Allan |
Sep 1 2005, 07:56 AM
PBC semi-mettalic with new /6 rotors. I was wondering if that if there was air in the caliper it might keep the pad from getting enough pressure against the rotor allowing it to vibrate. I have been doing quite a few 40 - 10 mph brake runs to try and get everything to bed in. Maybe it just needs a few more... |
Eric_Shea |
Sep 1 2005, 08:16 AM
PMB Performance Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
That'd be my guess... |
Lo-Fi Version | Time is now: 29th June 2024 - 07:45 AM |
