GaroldShaffer |
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None ![]() ![]() ![]() |
I'm starting to put together my winter project of suspension work. I have my Koni adjustable spring perches & springs and Weltmeister front adjustable sway bar coming soon from Rich (a914guy) and I am now looking at torsion bars.
PP has both the solid & hollow 21mm torsion bars at $240 (solid) & $291 (hollow). I have come to the conclusion that I want AX car that I can drive on the street so with that in mind is extra $$ for hollow torsion bars worth the money? What is the advantage of hollow over solid? Thanks (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) |
Jeroen |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe ![]() |
the advantage over solid is that they weigh less
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
they're a little bit lighter. they're pretty low, where a little additional weight is not a huge deal. i bought them for my 911, in part because rear torsions are pretty big and heavy and i wanted a matched set. in part, because i wanted the "ultimate" suspension i wouldn't be tempted to second-guess and "upgrade" again later. "worth it" for a car with rubber in the suspension? probably not. (i have no rubber in the 911 suspension.) YMMV. one additional minor factor - typically, the only people making the hollow bars are the good makers - e.g. Sander or Charlie - so you may be getting a bar with a better alloy of steel, better heat-treated, and with better, more accurately machined splines. might. |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
sway away also make hollow bars rich....
ArtechnikA |
i have some Sway-A-Way parts - i think my adjustable spring plates are S-A-W. they have a good reputation in axles and i'd see no reason they couldn't also make good torsion bars - they've been doing it for the SCORE crowd for 40 years. or is your meaning that you consider the Sway-A-Way parts to be inferior; it could be taken either way... |
Aaron Cox |
just throwing it out there that they also make hollows.....
anthony |
2270 club ![]() ![]() ![]() ![]() Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 ![]() ![]() |
I would get solid. I think the weight savings must be pretty small. Divide the weight loss by the extra $$$ and you'll probably come to the conclusion that the money could better be used elsewhere on the car.
GaroldShaffer |
Yep, that's what I thought too. Just wanted make sure there wasn't some sort of magic powers from using hollow torsion bars (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Lo-Fi Version | Time is now: 20th June 2024 - 06:10 AM |
