Red-Beard |
"Ya canna change the laws of Physics" ![]() ![]() ![]() Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None ![]() ![]() |
There is a local shop on my monday night route which remans CV joints. The machine the joints and install oversize balls. The 914/6 friggen joint is unique. At least 1 of mine has gone bad.
Has anyone tried this? |
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,086 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
Nope. Lemme know how it works out?
mikey |
Member ![]() ![]() Group: Members Posts: 424 Joined: 30-January 03 From: San Francisco Member No.: 214 Region Association: None ![]() |
My -6 CV joints were buggered too. I just replaced them with -4s at the recommendation of Brad and Rich Bontempi at HPH. They said the only difference between a -6 and -4 CV is that the -6 internally has one more spline. The dimensions, strength, outside appearance, etc of the -4 CV are the same as the -6.
Changing ball size sounds like a lot of trouble and expense. If you go that route let us know how much it cost and what the result was. (I still have my worn out -6 CVs that could be redone). |
mightyohm |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest ![]() ![]() |
mikey - where did you get your -4 joints?
I would like to know the costs of rebuilding also. Someone should go into business adapting VW CV's for 914's. All it would require is a lathe... |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
Jeff- which vw Cv's? and what is turned on the lathe? |
Engman |
Zoisite ![]() ![]() ![]() Group: Benefactors Posts: 1,349 Joined: 25-March 03 From: New Albany, IN Member No.: 475 ![]() ![]() |
Yep - got both seats redone locally for $100 - this was 5 years ago - 12000 miles and they are fine...
M |
mikey |
I got mine at HPH in Redwood City. Rich Bontempi had just got a bunch of them. |
lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
Hm. Perhaps buy a set to put on the shelf would be prudent. Did Rich indicate he had a steady supply, or did he just raid some secret NOS stash?
mightyohm |
New or used? |
mightyohm |
Oh and Aaron. I think they are just VW bug CV's.
Two holes need to be opened up to fit the dowel pins (and have a seat about 1/2" down to keep the dowels from going too far). The outside edge needs to be turned down a couple mm to fit the gasket. That is if we are going for a perfect replacement, you can "make things work" with no mods at all. But you know how much we like things to be original! |
mikey |
New. Don't remember what the cost was. I've heard that they periodically are hard to come by so I grabbed them as soon as they were available. |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
The reman people use a dedicated machine to hog out the recesses (built specifically for that purpose) and that is why they use an over size ball. Common practice.............
Red-Beard |
So, are you saying a 4 axel will replace a 6 axel? |
mikey |
Exactly - a -4 axle with -4 CV joints on it will replace a -6 axle with -6 CV joints on it.
However, you can't mix and match axles and CV joints, due to the fact that the -6 CV joint and axle have one more spline than the -4 CV joint and axle In all other respects (dimensionally) they are the same. |
Aaron Cox |
why didnt porsche have ONE cv for all early 911's and 914's?
one spline difference..... (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Because the axles, like the bodies, the engines, the trannies, and a lot more, were sourced from VW. VW used their CVs, modified, and Porsche used theirs. 911 CVs didn't come from any VW product or project. The Cap'n |
kart54 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 544 Joined: 27-January 05 From: Ventura, California Member No.: 3,520 ![]() |
Performance Products in the San Fernando Valley sells the complete axle for the 914-4 for $361.95 and the CV joint for $110.95 each. Just looked in my catalogue before writing this. Available now and have been for some time as far as I know. I bought a new pair of complete axles when I bought my car in February of this year. You can find them at www.automotion.com or call 1 800 423-3173. I have no affiliation with them, just a satisfied customer. Randy |
mikey |
Yipes! That sounds steep! I don't remember exactly how much I paid HPH, but I'm sure it was under $200 for each axle/CV joint unit. Jeesh, maybe they have gone up that much in the last year due to availability (or lack thereof) |
Lo-Fi Version | Time is now: 25th June 2024 - 11:08 PM |
