shaggy |
mechanic/welder/fabricator ![]() ![]() ![]() Group: Members Posts: 702 Joined: 26-September 05 From: Gilbert, AZ Member No.: 4,869 Region Association: None ![]() |
i have a crazy ass question...
can i put in a larger fuel tank? what about if i took out my one (bled it for sure!) then torched the side that faces forward and got another 914 tank did they same thing to it then welded them pack together made sure they were sealed and pressure tested it and put it back in? would the fuel pump handle all that? would i need to change me front suspension? ...or does this sound like an all together bad idea? |
736conver |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None ![]() |
Why? what do you want to achieve
McMark |
You could do it. You wouldn't have to fill up as much, but you'll add a ton of weight in extra metal and extra gas. Gas ain't light. Since you want to go faster you should forget about adding that much weight.
Air_Cooled_Nut |
914 Ronin - 914 owner who lost his 914club.com ![]() ![]() ![]() Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None ![]() |
How is 16 gallons not enough fuel capacity? (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif)
Flat VW |
Illegal Soapbox Derby Racecar ![]() ![]() ![]() Group: Members Posts: 1,692 Joined: 13-November 04 From: Phoenix, AZ Member No.: 3,105 ![]() |
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
I would check your dwell and timing, and make sure the vaccuum advance/retard connections are all good......
that helps MPG out..... the answer is maximizing usage of 16 gallons, not welding two tanks together...... b |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
if you can find one, some of the GTs had a 100L tank ... i know brad sold one to armando a few years back. they are out there. bring cubic $$$ ... (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) Andy Attached image(s) ![]() |
Hammy |
mr. Wonderful ![]() ![]() ![]() Group: Members Posts: 1,826 Joined: 20-October 04 From: Columbia, California Member No.: 2,978 Region Association: Northern California ![]() |
Seems like a *much* larger tank up front would affect the handling ? Or (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
In a GOOD way.. gets it closer to 50/50 you ever notice your car is more neutral with a full tank? |
Hammy |
Well ya with a full tank definitely feels better
... but say with a much larger tank filled all the way up and the weight balances were thrown off ? |
Aaron Cox |
ask a GT enduro racer (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
Hammy |
Are you saying that cause you don't know... Or are you mocking me (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) |
Aaron Cox |
lol... i have no idea. so i suggested asking someone with experience.... |
Lo-Fi Version | Time is now: 25th June 2024 - 08:53 PM |
