dlo914 |
Whatchu' lookin' at?!?! ![]() ![]() ![]() ![]() Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 ![]() |
the outboard motor mounts that hold up the engine bar:
Attached image(s) ![]() |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
how did you destroy yours??
Call pelican... or find a parts car.... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Use a pair of these. Competetion motor mount on the Bird.
mount them with the boss pointed up, and the side shifter bar will bolt right up. |
dlo914 |
both nuts & bolts holding the engine bar in place were heavy seized (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) |
michel richard |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 ![]() |
Or make some. Buy some square steel tubing of the right size, saw one side off. Saw and file to shape. Drill holes.
dlo914 |
would you happen to have the exact link? instead of the link to the image... |
dlo914 |
hmm good idea! |
machina |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 ![]() ![]() |
won't that move the front end of the entire drivetrain upwards about .75" ? |
michel richard |
I'm cheap and the hardware store is the cheapest (and quickest) source for parts! Just make sure you buy a new hacksaw blade. They're cheap too, and a new one will make a world of difference. Get 18 or 24 teeth per inch, no more. |
dlo914 |
sadly, ive only got a jigsaw. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) BUT a metal cutting blade on that thing works just fine. Does anyone know the size and length of the bolts that are required for this application? |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Mister PET says:
N 010 472 4 BOLT HEX-HD.M 10 X 85 (that's the big bolt through the middle) 900 075 085 02 BOLT HEX-HD.M 8 X 20 (those are the little ones through the sides of the mount) --DD |
michel richard |
Get a hand hacksaw. They're cheap. And with a sharp blade, with a low tooth count, it's amazing how quickly you will saw through square tubing. I'm sure people don't use hand saws only because they've never used one with a good fresh blade. |
dlo914 |
thanks Dave!!! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) |
dlo914 |
now for sure im gonna make these mounts rather than spending $20+ on a set (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
dlo914 |
could someone get the dimensions of piece #9? TIA! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Aaron Cox |
takle a piece of thick paper....
put it against theouter body mounts... and trace the 2 small holes. then MEASURE the distance, center to cener of these holes.. and mark the middle. now drill your big hole |
Triaddave |
Member ![]() ![]() Group: Members Posts: 244 Joined: 31-December 03 From: olympia,wa Member No.: 1,478 ![]() |
$20+ seems alot easier to me. i'm sure i have a box load of them. for the +, i'd even run them through the bead blaster, you pay shipping.
dbledsoe |
Mutineer ![]() ![]() Group: Members Posts: 300 Joined: 13-May 03 From: Boise, ID. Member No.: 687 ![]() |
I PM'd you that I have the mounts minus the bolts but got no reply. Perhaps I should have mentioned that they would only cost you the actual postage. (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif)
dlo914 |
how much for shipping? (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
dbledsoe |
I'm pretty sure that Priority Mail would be $3.85. They don't weight much. I can dig them out tonight box them and calulate shipping if you let me know your zip code. |
Lo-Fi Version | Time is now: 26th June 2024 - 04:44 AM |
