Frank Marino |
Newbie ![]() Group: Members Posts: 33 Joined: 13-June 03 From: Westchester, NY Member No.: 816 ![]() |
Everytime it rains, we get hydro-locked. Can't keep the car in the garage. Suggestions on how to keep the engine bay dry would be appretiated. Is there a part that goes under the engine lid?
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
It looks like a 6er???
Wolfert air cleaner housings....bring money. |
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
Do you have any more pics of the car? Preferably the front nose with the spoiler? I think thats the spoiler from Tweeks, and I have not seen it on a car before.
Thanks! Andrew |
airsix |
I have bees in my epiglotis ![]() ![]() ![]() ![]() Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 ![]() |
Sixes didn't have a rain tray under the engine lid like the -4's. You can get 'watershield' aircleaner covers for aftermarket filter setups, but if you've got the original -6 airbox it should be protected enough. What are you running now?
-Ben M. ps- I saw home-made -6 'waterhield' type aircleaner covers once made from rubbermaid containers. Not purdy, but it's a cheap fix. |
J P Stein |
Ah, my favorite pic. Note the recesses to direct water away from the carbs and into the drains(which you can't see). The "watershield's" base is flat.
(edit) you can see one drain, the little brass bit in the far center. Attached image(s) ![]() |
dmilzoff |
Member ![]() ![]() Group: Members Posts: 67 Joined: 2-March 03 From: Ossining, NY Member No.: 377 ![]() |
The car is an original 6 but has a 3.0L with twin 48 IDA Webers. They have watershed covers over the carbs and air filters but the problem is every time it rains. I think that the water is working its way in from through the head gaskets. Possible? I was thinking of installing an old style engine rain tray. Anyone have a source or a better suggestion?
tod914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 ![]() |
Purchase a 1/2 cover for it. I will cover the glass area and engine bay. Some1 posted info on them here.
If your storing it outside, invest in a decent full cover for like $160. Keep in mind, they are not 100% waterproof. In a torrent, they will seap water. |
scotty |
The Fun Never Stops ![]() ![]() ![]() Group: Members Posts: 773 Joined: 20-May 03 From: Portland. Oregon (SW) Member No.: 718 Region Association: None ![]() |
(IMG:style_emoticons/default/ohmy.gif) You leave it in the rain?!?!?!? (IMG:style_emoticons/default/ohmy.gif)
J P Stein |
QUOTE(dmilzoff @ Aug 8 2003, 04:09 PM) . I think that the water is working its way in from through the head gaskets. Possible? I should hope not. Your compression would be a tad low (IMG:style_emoticons/default/sad.gif) Note the pic of the Wolfert base....note the gaskets under the velocity stacks....got those? Do you have rubber gromets (washers) under the wing nuts holding the covers on? A rain tray as on the 4 bangers won't fit, but....I've heard of guys laying a piece of Saran Wrap over the engine grill to keep water out.....but don't forget to take it off when starting the motor !! BTW, if you don't get that thing out of the rain, it will degenerate into a pile of iron oxide. |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,107 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
i had to read the "can't keep it in the garage" part about 5 times. what's in the garage a bentley or a rolls? you can "make" a garage on the cheap. get some long lengths of plastic pipe, 3/4"should do, that isn't too rigid.various connections ie t's and 4 ways, some bungees, bags of sand and a large tarp. i like the type that has the silver coating on one side. form a quanset type frame and drape the tarp over it. use the bungees thru the grommets and around the frame. weight it down with the bags. instead of gluing the the frame together, drill the connection points and use some sort of pin to hold them together, the type with one straight side and a curve on the other, like hood pin clips. this will make it a break down/ mobile affair.
kevin |
Lo-Fi Version | Time is now: 23rd June 2024 - 01:27 PM |
