qa1142 |
Whiplash ![]() ![]() ![]() Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 ![]() |
So, she cranks and that is it. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
I'll check for spark first, but WTF, ran fine when I parked it a couple of days ago. (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) |
DonTraver |
Senior Member ![]() ![]() ![]() Group: Members Posts: 829 Joined: 5-August 04 Member No.: 2,461 ![]() |
Couple of years ago, same problem on my 6, drove me crazy, replaced complete ignition system ($2000), didn't help, etc. Turned out to be the relay board, the circuit are not soldered, the pins/circuit bars are a mechanical press fit. Over the years, age, vibration, etc, loosened the connections.
Try wiggling the cables at the circuit board, if it helps, that may be your problem. The fix is to strip off the covering on the bottom of the relay board and expand all the pins. Good Luck, Don |
pete-stevers |
saved from fire! ![]() ![]() ![]() ![]() Group: Members Posts: 2,643 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest ![]() ![]() |
of all the damn things...this 914 hobby is driving me to (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif)
qa1142 |
looks liked the good used pump I got 2 weeks ago just gave up. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
$73 down the drain. (IMG:http://www.914world.com/bbs2/html/emoticons/stromberg.gif) Looking for spairs, Late style single in and outlet. (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) |
type47fan |
It Looks Better In Person. . . ![]() ![]() ![]() Group: Members Posts: 860 Joined: 17-September 03 From: Carlsbad, CA Member No.: 1,170 Region Association: Southern California ![]() ![]() |
Will,
PM sent. . . . Thanks, |
Lo-Fi Version | Time is now: 25th June 2024 - 06:41 PM |
