> in-tank fuel filter, stock "T-1" filter
bd1308
post Oct 11 2005, 03:24 PM
Sir Post-a-lot
does it hang out in that circular thing on the bottom of the tank?
or is it somewhere else....
Replies(1 - 6)
Mueller
post Oct 11 2005, 03:25 PM
914 Freak!
where is the old one located??
bd1308
post Oct 11 2005, 03:27 PM
Sir Post-a-lot
i'm not going to take the tank out....
i think mine's already been removed......
Mueller
post Oct 11 2005, 03:31 PM
914 Freak!
you should be able to see it looking into the tank.....I don't think you can reach it from the top unless you have really, really skinny arms.........
lapuwali
Not another one!
It's on the end of the fuel outlet fitting, inside the tank. You have to drain and remove the tank to replace it.
bd1308
post Oct 11 2005, 03:34 PM
Sir Post-a-lot
okay....
well i DO see two little fittings (when looking into the tank) which i assume is where the filter would sit on top of
this is all in the cylindrical feauture inside the tank....
so i guess this means i dont have one....
tank looks nice though.....
Engman
post Oct 11 2005, 04:00 PM
Zoisite
Across the river in New Albany, IN there is little shop called "Happys" located at 153 E. Main ph.(812) 945-8921.
Its a little shop that specializes in VW bug parts, but they have the strainer sock as well as the proper sealant if you ever split the case.
M
- Lo-Fi Version Time is now: 4th January 2025 - 07:25 PM
