michel richard |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 ![]() |
As part of my /6 restoration, I am re-doing the whole wiring. I'm now looking at the steering column and associated wiring. I have 2 wiper switches, both the correct part number:
Attached image(s) ![]() |
michel richard |
The problem is the connector at the end of the little bundle, at the right in this picture:
michel richard |
I can find nothing in the main wiring harness that would connect to this plug. The wiring diagram that I have shows both the wiper and the blinker switches as one item, and does'nt really help. I looked at the PET parts diagrams, and can't find help there either.
Does anybody know what it is that I am missing, or can't figure out ? Thanks |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,442 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
The steering colum wiper lead plugs into a bulkhead receptacle, that comes right from the -6 wiper motor.
914-6 only wiper motor. |
michel richard |
OK,
I knew there was something I did'nt understand ! I believe I have a /6 wiper motor, in one of the boxes, so that should not be a problem. I'll go look and let you know. Thanks |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,597 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
The plug on the wiper motor looks like the plug for a round relay. It fits in the hole where the windshield washer hoses come through the bulkhead on the /4.
The harness on the six will only have a lead for the power to the wiper motor, nothing else. |
michel richard |
I have found a /6 wiper motor, and I now remember that Jon Lowe had said it was different, although I could not remember why.
Here's a picture, in case it's of interest to anyone. The special lead is the one that's a little higher. There's a big rubber grommet/fitting so it can be fixed to the bulkhead. Attached image(s) ![]() |
sixnotfour |
the other lead is for the washer pump. (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif)
michel richard |
Jeff,
Thanks, I had not yet figured that one out either ! |
Lo-Fi Version | Time is now: 2nd July 2024 - 11:58 PM |
