Cable Shifter Conversion, Lost the site..... |
Mr.C |
Nov 3 2005, 04:42 PM
Easy does it Group: Members Posts: 612 Joined: 31-December 02 From: Central Cal Member No.: 61 Region Association: None |
Can any of you guys point me to the site where the guy converted his tailshifter to cable? Or was it a sideshifter? He used parts I believe out of an Eclipse.
Thanks |
DBCooper |
Nov 3 2005, 04:57 PM
14's in the 13's with ATTITUDE Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
Mr.C |
Nov 3 2005, 05:02 PM
Thanks Paul, that's the one. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
lapuwali |
Nov 3 2005, 05:47 PM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
He used the shift lever out of an Eclipse, but pretty much any cable shift lever will work. The arrangement at the transaxle he made himself, and it looks like you could drag battleship around with it, it's so, um, sturdy. Someone else posted a photo of a tailshifter with Hyundai Scoupe linkage bits at the back, which not only required a lot less fabrication, but are much smaller and lighter than Eric's setup, too. Again, I strongly suspect the transaxle linkage bits from many cable-shifted cars could be adapted to the tailshifter.
Mr.C |
Nov 3 2005, 08:28 PM
Cool thanks for the info.
What I'm looking into doing is flipping the ring gear and using this cable set-up for a Westy. This should solve the linkage problem. It's going to be watercooled. Did I sneak this in under the OT radar? (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) |
Lo-Fi Version | Time is now: 4th January 2025 - 07:35 PM |
