5dogs |
Newbie ![]() Group: Members Posts: 15 Joined: 18-September 04 From: Eureka, CA Member No.: 2,784 ![]() |
I have a bad starter. Went to the local auto parts store and had it tested. He then said he had one in stock. I pulled it out of the box for comparison, and it did not look the same. He checked all his numbers and checked different years. All the same. The difference was in the gears/teeth. Mine has a white plug on the end of the gear while the new one has a shaft about 1 1/2 inches long. I don't know if I am describing it right. Hopefully, one of you guys will know what I am talking about. I did not buy the starter buy the way. Any help would be appreciated. thanks.
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
It's an error in the parts book. I believe that the one he showed you was for an automatic Bus. The correct part number is SR-17X.
--DD |
Always Looking |
Member ![]() ![]() Group: Members Posts: 194 Joined: 9-December 04 From: Orange, CA Member No.: 3,246 ![]() |
I had the same problem from Kragen in my area. I have a 72 and finally asked to look at the started for the 73. The showed me a totally different starter. On the correct one, the whole shaft slides out of the starter, not just the pinion gear on a shaft. Post or pm if you have more questions. Sorry for the bad description. (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif)
scruz914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 815 Joined: 26-February 04 From: Santa Cruz, CA Member No.: 1,724 ![]() |
Lo-Fi Version | Time is now: 25th June 2024 - 09:23 PM |
