grasshopper |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,613 Joined: 10-December 04 From: Valdosta, GA Member No.: 3,258 Region Association: None ![]() |
ok, is 85 bucks a good deal for rear five lug hubs??? It says "drilled for the 130MM 5 bolt wheel pattern". What else would i need, to do the five lug conversion on the rear?? the front seems pretty straight forward. Thanks!
Series9 |
Lesbians taste like chicken. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States ![]() |
IMO $85 is a reasonable price for drilled 5-bolt rears. Some will say they should be redrilled EARLY hubs, but personally I think either are just fine.
You'll also need new bearings, studs, lug nuts and /6 rear rotors. |
gregrobbins |
Member: Team NARP ![]() ![]() ![]() Group: Members Posts: 1,515 Joined: 23-March 04 From: Arizona Member No.: 1,844 Region Association: Southwest Region ![]() |
I need a source for rear five lug rotors. Mine are getting down to the point they can no longer be "turned."
Are new units available? Where? Thanks Are the 914-6 and the 911 rotors the same? Anyone with a part number? |
Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
Pelican and GPR both have them. I got a set from Pelican a couple of months ago for something like $75.00 ea. |
grasshopper |
what about brake calipers??? what will work?
Series9 |
Your stock /4 calipers will work. |
736conver |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None ![]() |
If you think $85 is good how about $50.
Check my classified post out. They are the later hubs link to post |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,162 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
No, the 911 is vented, the 914/6 is solid, plus the offset is different. The 911 is 4mm larger in diameter than the 914/6 and 8mm larger than a 914/4. You could go to the vented rotors if you used my kit to convert the calipers, and space the rotors. |
goose2 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 976 Joined: 30-March 05 From: Eugene, Oregon Member No.: 3,847 Region Association: Pacific Northwest ![]() |
Very early 911 rotors (68-69 ?) are non-vented and in most cases will fit, but not always, I'm told. It seems the diameter varies and may be too large. I have a pair I'm going to try on my rear conversion before I spring for the 914-6 versions.
anthony |
2270 club ![]() ![]() ![]() ![]() Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 ![]() ![]() |
$85 will the tip of the iceberg on your 5 lug conversion. Figure on at least $1500 when you refresh everything (rotors, pads, brake hoses, bearings, bushings, etc). You also need to find 5 lug wheels.
The hubs should have studs installed. |
Leo Imperial |
Do you have to use so many cuss words? ![]() ![]() ![]() Group: Members Posts: 906 Joined: 29-November 04 From: 914 Roadshow - Glen Cove NY Member No.: 3,192 Region Association: None ![]() |
$1500 (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) Don't be detered. Complete control arms w/cores from Eric $395 Rotors from Pelican $76.35/each Pads from Pelican $25.45/pair Rear bushing kit $36.60 Total $609.75 You could spend more, but I think this is a pretty good ballpark. Finding a set of 5 lug wheels. Well that is up to you, but cookie cutters are a cheap option for under $100/each. Shop around and you can do better than this. Just my $0.02 |
Leo Imperial |
Actually if you are talking about the fronts also $1500 is pretty close.
grasshopper |
cool, ..... i already have a set of 5 lug fuchs from the 911 we cut up (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
pete-stevers |
saved from fire! ![]() ![]() ![]() ![]() Group: Members Posts: 2,643 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest ![]() ![]() |
come on now the 1500 includes plating with gold....but seriously you could buy early 911 hubs with that kinda pricing....I have a set but i am not selling mine...nope (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
JoeSharp |
In Irvine, Ca. May 15-18 ![]() ![]() ![]() ![]() Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States ![]() |
anthony |
No, actually $1500 just includes refreshing your suspension with new parts rather than used parts. 911SC front end.................400 brake pads front...................35 brake pads rear....................35 911 vented rotors front........94 914-6 rotors rear................152 5 lug rear hubs...................100 brakes hoses........................52 rear wheel bearings...........102 turbo tie rods.....................177 ball joints............................113 16x6 Fuchs.........................600 tires....................................450 19mm master cylinder.........193 total..................................2503 No gold, just new fresh parts. All prices are from Pelican. Are you going to do a new suspension and then installed used brake pads, used rotors, a used master cylinder, etc??? All that little stuff adds up. IMO, if you aren't going to do it right then stay with a 4 lug setup. |
Lo-Fi Version | Time is now: 25th June 2024 - 08:47 PM |
