> Oil Pumps for T4 Race Motor, Schadeck T4 30mm Full Flow Oil Pump
GBallantine
post Nov 15 2005, 11:01 AM
Anybody out there have any experience in running the Schadeck oil pump in combo with a front mounted oil cooler setup. Can it provide enough pressure to circulate thru the system? Is there any other pumps worth considering? Who sells these pumps?
GB
Replies(1 - 2)
groot
post Nov 15 2005, 12:07 PM
Dis member
I've heard they work fine... but no personal experience with them.
I'm running a 30mm Melling (not by choice, it's just what was on the engine) and it does fine for a wet sump system... Jake Raby has lots of decent pumps for the type 4 that will work.
I'm converting to a dry sump system, though for the long term.
Jake Raby
post Nov 15 2005, 03:54 PM
Engine Surgeon
I have used my modified Schadek pumps with good results- BUT only if the engine was full flowed with my plumbing changes.. I have had ill results when doing the mod with a sandwich adaptor or oil cooler adaptor and going to a front cooler..
I sell the entire full flow kit, or just the pump (The entire arrangement is only 130 bucks for the standard full flow set)
- Lo-Fi Version Time is now: 5th January 2025 - 03:53 AM
