> Suspension Bushings, Needle vs. Bronze control arm bushings
makinson1
post Aug 19 2003, 01:30 PM
I may want to replace the worn out plastic control arm bushings in the front end. Should I use the needle bearing units or the solid bronze ones with the grease fitting?
Replies(1 - 12)
Brad Roberts
post Aug 19 2003, 01:33 PM
914 Freak!
Roller all the way. It makes NO sense to install a "hard" anything in the suspension.
I'm jaded. Nothing but roller for our cars. Once you have driven a roller car... compared to a plastic car.. life changes when it comes to driving.
B
Lawrence
post Aug 19 2003, 01:37 PM
Check the Classic Message Threads section.
Suspension Time
Rear Suspension Ear
Suspension Question
I hope these help.
-Rusty (IMG:style_emoticons/default/smoke.gif)
seanery
post Aug 19 2003, 01:49 PM
waiting to rebuild whitey!
Hey Mueller, if I get this insurance thing fixed quickly I may want a set of front & rears for the white car that B has.
Any in stock or available in the next 10 days or so. (I'm not sure how long it takes to finish the deal with the Ins. co.)
736convers
post Aug 19 2003, 02:38 PM
I am also curious is there a wait time from when you would place on order for the bearings. My front end will be rebuilt soon and I plan on going that route.
Mueller
post Aug 19 2003, 04:50 PM
914 Freak!
Biased opinion here(you don't say?!?!)LOL
The needle bearings are a much more precise item, the interferance between the bearings and the shaft is held to within .0005 of an inch.
The needle bearings are closly related to the wheel bearings inside your front hubs (and these sure take a beating, wouldn't you say? (IMG:style_emoticons/default/smile.gif) )
Bronze bushings are closer related to the bearings inside your engine. Sure they stand up to tremendouse forces, but you also have to remember that the oil is constantanly being pumped in between to create a layer to prevent damage. Yes, the bronze bushings do have grease fittings, but after a few cycles up and down the grease will no longer be able to protect the mating surfaces between the bronze and the metal sleeve (unless you had means to constantly supply new grease)
The needle bearings have an initial higher up front price, but in the event any of the bearings need to be replaced 5 years down the road, the bearings can be bought for a fraction of the kit price (~$15 bucks per housing).....the main cost in the kits is the housing that the main bearing fits into (made from Seamless tubing to prevent spliting) and the sleeves (made from a solid rod of 52100 steel, then it is hardened and centerless ground. How hard?, about the same hardness as the big ball bearings inside a CV joint)
Front and rear kits are in stock...(I'm out of town from tommorow until next Thrusday)
ArtechnikA
post Aug 19 2003, 04:53 PM
rich herzog
QUOTE(Mueller @ Aug 19 2003, 02:50 PM)
...made from a solid rod of 52100 steel, then it is hardened and centerless ground.
sorry - slightly off-topic -
what exactly does 'centerless ground' mean ? i've seen it used for years, i know it's A Good Thing - but i have no idea what it means - exactly.
Mueller
post Aug 19 2003, 05:28 PM
914 Freak!
Rich,
Centerless Grinding
http://www.efunda.com/processes/machining/...ss_grinding.gif
Instead of holding the material in the middle (axis) the motion to turn is by means of a roller.
seanery
post Aug 19 2003, 05:50 PM
you use the "through-feed" process?
Mueller
post Aug 19 2003, 05:54 PM
914 Freak!
Sean,
I don't personally do the grinding, I have a shop that speciallizes in this material do the sleeves, I don't have that kind of capital to spend on equipment (IMG:style_emoticons/default/smile.gif)
seanery
post Aug 19 2003, 05:56 PM
OK, how 'bout this?
Your product is done in the "through-feed" process?
Mueller
post Aug 19 2003, 06:12 PM
914 Freak!
thru-feed would be the correct choice !!!
The housing are turned the traditional way on a lathe (bar-feed CNC)
If your 951 is totalled, someone in the classifieds is looking for some phonedials, not sure if you have them or are buying the car back.
seanery
post Aug 19 2003, 06:24 PM
my car had fuchs, but I took them off for the 914-6 (16x8's for the front) and put on some boxster S rims.
- Lo-Fi Version Time is now: 29th April 2025 - 06:03 PM
