ford conversion |
ford conversion |
zainman |
Nov 30 2005, 08:23 PM
Newbie Group: Members Posts: 29 Joined: 19-September 05 From: Hamlin NY Member No.: 4,827 |
Does anyone have pics of a Ford v8 conversion? I'm going to do this conversion so don't try and make me do a Chevy.
shaggy |
Nov 30 2005, 08:32 PM
mechanic/welder/fabricator Group: Members Posts: 702 Joined: 26-September 05 From: Gilbert, AZ Member No.: 4,869 Region Association: None |
351?
289? 302? 428? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) what are you putting in? |
jd74914 |
Nov 30 2005, 08:33 PM
Its alive Group: Members Posts: 4,782 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
No pics but I have heard of one with a 289.
Eric_Shea |
Nov 30 2005, 08:41 PM
PMB Performance Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Everyone chant "SHO, SHO, SHO..."
I'd love to see a SHO motor in a teener. I swear, one of the best motors I've ever owned. |
andys |
Nov 30 2005, 09:56 PM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
Here is just one of several threads on the SBF in a 914. I did a lot of measuring, etc as well.
Andys http://www.914world.com/bbs2/index.php?act=...&t=33997&hl=sbf |
Rand |
Nov 30 2005, 10:05 PM
I have fond memories of a 351 Windsor.... Great motor. Ran super strong for 200k miles. I only wish it was in a 914!
IIRC, the dimensions make it a bit more of a fitment challenge. I think it's longer and requires some firewall work? Of course anything is doable. It will just take more custom work. The SBC is a lot easier because of the all the aftermarket kit parts. |
dflesburg |
Dec 1 2005, 09:32 AM
Senior Member Group: Members Posts: 1,720 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
I think the engine from my '03 Cobra would be best
bondo |
Dec 1 2005, 10:18 AM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
Here's a ford powered 914.
Mueller |
Dec 1 2005, 12:04 PM
looks the same as a Chevy install except for the distributor being on the front of the motor (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
jd74914 |
Dec 1 2005, 01:01 PM
Not if youuse a new 5.0 with efi Crankfire IIRC (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) |
Crazyhippy |
Dec 1 2005, 01:19 PM
Insert witty comment here... Group: Members Posts: 1,659 Joined: 28-July 05 From: Home of the Coyotes, AZ Member No.: 4,493 Region Association: None |
Tried the high output taurus motor from 2002... it was WAY to tall, stuck through the decklid, not just the trunk floor too tall... Then there's all the damned sensors... ever tried to install a fuel tank temperature sensor?? (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) BJH |
Crazyhippy |
Dec 1 2005, 01:24 PM
The motor itself is roughly the same size... it's the waterpump/timing cover BS that adds so much length. Very do able conversion, but takes some high end fabrication on the front of the motor. Might also have issues w/ distributor clearance??? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) BJH |
zainman |
Dec 1 2005, 09:22 PM
The engine will be a 91 5.0 from a Mustang LX, and I just happen to have at my disposal some Cobra parts, intake and heads. I took a look at the pics of the can am style 914 from Sean, but I still can't tell if there is a clearance problem with the distributor. I think he said it has a dist. I noticed his pics were from last year, has he finished the car.
andys |
Dec 1 2005, 10:01 PM
BJH has got it right. Fabrication of either a special cover, or custom water inlets is required IF you don't cut into the firewall. As for the distributor, you can use a late model Explorer motor with the EEC-V distributorless ignition. If you cut into the firewall, and make a sheetmetal cover, then I would think you could make it fit quite well. There was a 5.0 914 for sale in SoCal about two years ago. I have comparative dimensions of a SBF, SBC, and LS1 motors at the office. Andys |
zainman |
Dec 2 2005, 05:41 PM
914 will be coming next week to my house, have to make room in the garage. It's a 72 that has been in storage for 20 years, when I get it here I'll start to take some pics and hopefully figure out how to post them
Rand |
Dec 2 2005, 06:01 PM
Hmm... That car is in Coos Bay Oregon... I lived there for 15 years before moving to Seattle. Hey Sean!! I sent you a PM. Are you still on the board? |
Eric_Shea |
Dec 3 2005, 02:02 PM
I was thinking the 6 not the 8. I was never a big fan of the 8 |
Lo-Fi Version | Time is now: 26th June 2024 - 01:13 PM |
