sean_v8_914 |
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 ![]() |
2.0 D Jet, new engine. it ran fine yesterday. I changed the points with a compufire. the idle smoothed out nicely. I touched something wrong because now it hesitates past 1/2 throttle under load. below 1/2 throttle its nice. on teh fwy its fine (IMG:http://www.914world.com/bbs2/html/emoticons/WTF.gif)
sean_v8_914 |
I like posts with pics
Attached thumbnail(s) ![]() |
sean_v8_914 |
this one
swl |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada ![]() |
vacuum to the MPC? or perhaps another vacuum leak? MPC adjusts the fuel pulse for load.
BTW that is a beautiful engine. |
JoeSharp |
In Irvine, Ca. May 15-18 ![]() ![]() ![]() ![]() Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States ![]() |
Sean: Did you do your 10 point check.
:PERMAGRIN: Joe Attached image(s) ![]() |
Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
Don't know about the hesitation problem but where is your alternator cover?
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,575 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Are your dizzy weights sticking? One drop of 30 wt on the center felt per year is what Haynes says to do...
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Re-check the timing, 28-32degrees BTDC @3500rpms
Both advance and retard hoses still on? |
sean_v8_914 |
someone show me what an alternator cover looks like please
sean_v8_914 |
yes Joe
thats a cheap shot, I need that knee cap |
John |
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None ![]() |
It sounds like a leak in the MPS or one of the hoses leading to it.
I would try checking there first. You may have inadvertently bumped a hose loose. Is it running excessively rich or lean? Or is it just hesitating? I had one once that wouldn't pull past 3500 RPMs to find that the coil had shot craps. Good luck. |
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,086 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
Hey Sean
Did you re-time after installing the pertronix? |
sean_v8_914 |
yup, re-timed it. just checked total adv again, 29 deg. Ill go check that MPS hose again.
it does run very rich. I can smell it |
Bleyseng |
You unplugged the CHT and its running way rich...........
Lo-Fi Version | Time is now: 26th June 2024 - 02:05 PM |
