Nick |
Member ![]() ![]() Group: Members Posts: 144 Joined: 25-June 04 From: Washington DC Member No.: 2,250 ![]() |
I spent today installing new rear wheel bearings and that went OK I think. I left the swing arm on the car and just unbolted the rear brake calipers, but left all the lines connected. I backed out of the garage and the brake pedal went straight to the floor. Pumping didn't seem to help. I can see no leaks and the brake fluid is full. I lift the car off the ground again and had a helper step on the brakes. all the wheels locked to the point I couldn't turn them by hand. I guess the question is what should I look at next?
Nick |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Two things...
1. check the venting clearance on the rear pads. 2. Bleed the brakes. |
Nick |
I should have added brakes are off and 80's 911 so I think there are no venting clearance issues. As for Bleeding I'll give that a try, but the brakes felt great on the last trip. I'm guess it is a Master Cylinder failure, but would like to do some trouble shooting before I order a new one.
Nick |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
If you suspect a M/C you should check the floor around your pedal assembly. Any failure will probably show up there.
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
To fit the calipers back over the rotors, you did have to push the brake pads back in a little ways, right?
That first press of the pedal pushed the pads against the rotor. It's perfectly normal, and is the reason that you always pump the pedal a time or two after you do any brake work. --DD |
Nick |
Pumped the brakes like crazy and it doesn't help at all.
Nick |
Lo-Fi Version | Time is now: 26th June 2024 - 05:06 AM |
