joea9146 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 663 Joined: 10-February 03 From: Denver, NC Member No.: 283 Region Association: None ![]() |
Anyone running 993 or 996 wheels on a flared 914
looking at 17 x 7 offset 7-55 and 17 x 9 offset 9-55. Not sure what size spacers I would need to maker these work . looking for someone that has done this ? |
smrz914 |
Soon to be brightening the life of the person behind you. ![]() ![]() Group: Members Posts: 456 Joined: 21-April 03 From: Pleasant Hill, CA or Chico, CA Member No.: 596 ![]() |
17x7 front 17x9 in the back 993's 1.5" spacers all around but probably could go with 2" in back. Front fenders are pulled a little and I had to trim the front lip so I could steer.
Edit: The tires are 225/40 front and the back are 255/35 Bridgestone SO-3. Just the perfect tires for these wheels. I don't think all 255's will work but my tires have the bead pretty far in towards the center of the tire. (IMG:http://www.pelicanparts.com/MotorCity/smrz9148/silverSideView.jpg) (IMG:http://www.pelicanparts.com/MotorCity/smrz9148/silverRearFlare.jpg) I no longer have stock rear breaks. so this last pic is outdated. (IMG:http://www.pelicanparts.com/MotorCity/smrz9148/silverRearRotorBehindWheel.jpg) |
Series9 |
Lesbians taste like chicken. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States ![]() |
100mm wheel studs and 42mm spacers all around:
Attached image(s) ![]() |
andys |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None ![]() ![]() |
I have the same wheels which I intend to run on my recently started f'glass flared car. I did a trial fit of the rears (255-40-17) and find I'll have to trim the inside lip. Without hijacking this thread, can someone with this combination tell me how far they timmed the lip (or how much lip is remaining)?
Thanks, Andys |
Series9 |
I have steel flares on the RS and I had the lip completely folded. However, I have plenty of room and probably didn't need to do this, but at the time, I wasn't sure and didn't want to take a chance. |
joea9146 |
Joe....
What Size tire are u running ? Thanks |
Series9 |
255/40 and 225/45 |
Lo-Fi Version | Time is now: 25th June 2024 - 07:58 PM |
