tat2dphreak |
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region ![]() ![]() |
I have a 2056 now with webers, but, since I know how much it is disliked to have carbs with anything resembling a stock cam, I've wondered if L-Jet or Djet can be used effectively on a 2056... if so, which is easier to obtain, maintain, and tune for a complete FI newbie?
r_towle |
Djet is basically plug and play...
Send the MPS to one of the tuners here to set it up for a 2056. The rest is just putting it in, no real tuning needed provided you have a good mps that is set up correctly. It has been done, it is still being done and provided you have a stock cam, it works great. Rich |
sean_v8_914 |
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 ![]() |
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Another way is to get the d-jet stuff and do a Megasquirt (or SDS, others) and have a bit more flexable system.
Dave Hunt has the maps for MS, I have the maps for SDS...so this is an option. Even with the maps I'd still borrow or buy a wide band. I'd use a 2.0 plenum, etc., with 1.7 injectors. I'd stick with MS or SDS just because you know for sure Dave or I would help you and we both have proven working Type 4 systems. |
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
1) SDS EM-4 looks like a good system. i think i will install that on my next engine.
2) L-jet since parts are still available. D-jet MPS's are around $6-800. |
bd1308 |
unless you want a NOS unit, which are NLA.
b |
tat2dphreak |
is an aftermarket MS system easier for a newbie than D-jet? I don't know if I'll do it either way, but it was just a thought... it would have to be much less than a grand before I consider it any FI system, too |
Tom Perso |
Crazy from the Cold... ![]() ![]() ![]() Group: Members Posts: 647 Joined: 8-August 03 From: Kalamazoo, MI Member No.: 1,003 ![]() |
tat2dphreak |
you hush,... you started this...(IMG:http://www.914world.com/bbs2/html/emoticons/spank.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) is your's running MS yet? |
Tom Perso |
Heck no! That's why I'm telling you to do it so I can live vicariously thru you! (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) I need an engine first. I may be building one now soon. Tom |
tat2dphreak |
heh, you'd probably still have your's going first... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
A D-Jet MPS doesn't have to be $800. Ones that hold vacuum show up on Ebay or here in the classifieds for a lot less than that. If they were all $800, I'd sell the 2-3 I have and buy a Tangerine header with the proceeds...
L-Jet may be a tad small for a 2056. It would work, but you'd potentially lose some top-end because of the AFM restriction, since it was sized for a 1.8. MS or SDS using 2.0 D-Jet parts and 1.7 injectors, however, would be easy to do mechanically and electrically. I certainly hope so, anyway, since I'm planning on doing just that to my 2.2 this year. MS is a fine system if you can handle doing your own wiring and don't hate computers. If you can't stand computers and want more hand-holding, SDS is a better bet. |
Lo-Fi Version | Time is now: 25th June 2024 - 07:45 PM |
