another, stupid question |
toon1 |
Jan 11 2006, 08:25 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
I have some of the rubber motor mounts that go between the block and the engine bar. All three of them have a sortof wedge shape to them. Is this normal? If so, how is the mount supposed to bolt to the metal braket that bolts to the block? (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
r_towle |
Jan 11 2006, 08:29 PM
Custom Member Group: Members Posts: 24,597 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
There are no stupid questions...
Only stupid answers. If you are talking about the side shifter engine bar, you will have twm metal "L" brackets that are bolted horizontal on the front of the engine case... The rubber mount has a threaded rod sticking out of both ends. One bolts to the "L" bracket, the other bolts to the engine bar. Look on Pelicans site for a pic. Rich |
toon1 |
Jan 11 2006, 08:44 PM
those are the rubber mounts that I have. But they seem to have a wedge shape to them, one side is thicker than the other. I am wondering if there is an orientationwhen they are placed on the L braket between the motor bar. Is this wedge shape like this because it took a set from being on the motor?
Joe Ricard |
Jan 11 2006, 08:48 PM
Nope should not be wedge shaped. I think I got a couple just pm we can work out the particulars.
r_towle |
Jan 11 2006, 09:08 PM
Not supposed to be wedge shaped.
Buy new ones...they are a real drag to replace...gotta take the motor out, gotta take off the front fan hosing... Do it once, they should be good for another 30 years. Rich |
bondo |
Jan 11 2006, 09:14 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
I replaced mine with the engine in place and fan housing on. Just had to support the engine and take off the engine bar. (not even all the way, just one side if I remember right) Still a pain though, I don't think I'd use used ones. |
Dave_Darling |
Jan 11 2006, 11:59 PM
914 Idiot Group: Members Posts: 14,992 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
If the wedge is very pronounced (like 30 degrees or so), you may have Bus mounts. If so, find a Bus guy to use them--you need the 914 version.
--DD |
Joe Ricard |
Jan 12 2006, 05:47 AM
Good point Dave.
Mine are new enough to still have that powdery stuff on them. I don't use them. Let me know. Yup I did it like Bondo jack under the motor pull the bar down. I think it is easier than adjusting valves. |
toon1 |
Jan 12 2006, 09:22 AM
They are definetly porsche mounts, worn out mounts at that. I have one that is ok( no wedge shape) but it is on the crusty side.The three that are wedge shaped look in better shape than the good one but for some reason they have the stinkin wedge shape goin on. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Allan |
Jan 12 2006, 09:28 AM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
There should only be 2. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Oh wait, you have 3 extras.. |
toon1 |
Jan 12 2006, 09:48 AM
I know there are only suppossed to be two on the car. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) I actually have five mounts total, one is usable, ons is cross threaded and three are wedged
Cap'n Krusty |
Jan 12 2006, 10:07 AM
You DO NOT have to remove either the motor or the fan shroud to replace either the mounts or the brackets. The Cap'n |
toon1 |
Jan 12 2006, 10:28 AM
I removed them with the motor is the car. The motor has to come out to replace engine shelf seal.
toon1 |
Jan 12 2006, 11:12 AM
Hey Joe, PM sent (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Lo-Fi Version | Time is now: 21st June 2024 - 12:11 AM |
