94teener |
Member ![]() ![]() Group: Members Posts: 209 Joined: 6-February 04 From: Jacksonville, FL Member No.: 1,636 ![]() |
This would be a fun project to install on a 914-4. I have a rather larger unit I'm putting togather.
Phil http://gaprojects.com/supercharger/supercharger.htm |
MattR |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,279 Joined: 23-January 04 From: SF Bay Area Member No.: 1,589 Region Association: Northern California ![]() |
Cal Poly Pomona used an electronic powered forced induction on their FSAE car in 2000 iirc. I think the major problem with it is the electricity needed to run a high power motor. You're pulling a lot of juice off the engine to keep the high powered motor running. There is no such thing as "free" power. You're pulling more resistance from the alternator to power the motor.
Newton had to be soooo smart with his laws of conservation of energy... (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) |
Twystd1 |
You don't want to know... really..... ![]() ![]() ![]() ![]() Group: Members Posts: 2,514 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 ![]() |
This setup has been tried many times.
And failed misserably by that all that I read about it for many techinical reasons. Bottom line is that it does work.ok for low boost and very short duration performance. YET....... There apparently isn't any good way to keep enough juice on board to make it work well as a daily funtional design. Search the net for the storys. there are many of em... Regards, Twystd1 |
Lo-Fi Version | Time is now: 20th June 2024 - 06:02 AM |
